Need help with fuel system
Old Aug 2, 2017 | 08:02 PM
SAMzG35's Avatar
SAMzG35
Default Need help with fuel system
I'm getting a built block and aiming for more power.
My current setup is walbro 255lph, CJM stage 0 return/regulator, DW 600CC injectors. Stock rails.
What would be the max power I can expect from the current fuel system? What should be upgraded next? rails? Injectors? lines or pump?
Also any idea whats the max power/boost from a Greddy kit with TD05-18G?
Thanks
Old Aug 3, 2017 | 06:36 AM
eZg's Avatar
eZg
Have you contacted Charles....THE Charles who is CJM?
Dude knows his fuel ****!
Old Aug 3, 2017 | 10:42 AM
bealljk's Avatar
bealljk
with a stage 0 and 600cc injectors you may be able to hit 425whp.
upgrade your fuel system, fuel pump, and injectors simultaneously.
what are you using to tune?
Old Aug 3, 2017 | 10:55 AM
eZg's Avatar
eZg
I have same fuel pump with 800 injectors and Haltech dynosty tuned my 18g's to 503 whp.
I've wondered if the new walbro (what-is-it?) 485 would be worth a retune or if I'd have to go twin pump for any real gains.
Old Aug 3, 2017 | 01:48 PM
SAMzG35's Avatar
SAMzG35
What held you back from going for more power? Fuel?
Old Aug 3, 2017 | 01:53 PM
bealljk's Avatar
bealljk
Do you have a return fuel system? and can you check the duty cycle of your injectors?
my duty cycle on my 1000cc is around 40% so I'd imagine 800cc is around 60% ... which means the fuel pump went first
Old Aug 3, 2017 | 02:30 PM
SAMzG35's Avatar
SAMzG35
I'm currently on 461whp & 445wtq on dynojet with my current fuel system tuned with uprev.
New management might be PROEFI.
Old Aug 3, 2017 | 04:44 PM
bealljk's Avatar
bealljk
^wow! Can you monitor your duty cycle?
how much boost?
Old Aug 3, 2017 | 05:13 PM
SAMzG35's Avatar
SAMzG35
how much boost?
Nope. Don't think I can. At 11-12psi stock block looool
Old Aug 3, 2017 | 06:41 PM
bealljk's Avatar
bealljk
Dear Colorado,
I'd like you to return all the horsepower you've stolen from me.
Your Friend,
James
