FRS fuel return system low boost build
Old Sep 14, 2017 | 09:45 AM
Wet feet's Avatar
Wet feet
5 Year Member
Default FRS fuel return system low boost build
Hi guys, yes I've read all of the turbo/noob stickies and hours of debating threads on the FRS subject. Many threads here are 10 years old from the Mayhem guy and a couple other threads. I'm just wondering if, over a long period of time, say 5+ years, someone has run their low (7) boost build without a fuel return without any ill effects, but with a good tune? I know it's recommended and safer, as well as easier to tune with a frs., but have also read it's doable. I will get a frs system if it's necessary, not looking to cheap out, but instead would love to direct the funds to some tires, suspension and other needs. I know a safe motor build is a lot more important than tires. I'm building for the popular, "safer" 380whp area that would leave the block stock.
I'm doing a pieced together build, Borg Warner k27, Turbosmart accessories, AEM gauges, Walbro, Bosch 560, Mishimoto Z IC, Z1 test pipes, Z1 clutch kit, probably Osrisis depending on which tuner I use.
Just looking for a little insight. Will get the CJM 0 stage from Z1 if necessary.
I suppose I should add that it's a Sunday garage queen, not tracking it or anything like that. Only 15k original miles.
Old Sep 14, 2017 | 10:39 AM
iideadeyeii's Avatar
iideadeyeii
Not necessary
Old Sep 14, 2017 | 08:32 PM
Nic Boitnott's Avatar
Nic Boitnott
Not needed, I'm at 7psi and 395whp no problem.
Old Sep 14, 2017 | 08:46 PM
Wet feet's Avatar
Wet feet
5 Year Member
Very interesting! Just curious, which fuel system mods do you have, the usual Walbro, drilled fpr and 600 injectors? ECU flash?
Sounds like a good place to be hp/psi-wise with the stock block.
