Cosworth hR/VHR Headgaskets are no longer available!?
Ive checked all the major venders and I can’t seem to get a set of Cosworth HR/VHR Head gaskets. Anyone know where I can get a set? ConceptZ and Z1 are out.
I'd recommend considering Dynosty head gaskets, that's what I went with this second time around and haven't had coolant issues (whew!). I've tried HR stock head gaskets & Cometic both of which failed. Been fine since going with Dynosty's.
I'd go with an HR gasket ... readily available and not too expensive. The best head gasket in the world wont save your engine from a bad tune or improper head-stud installation.
I ended up getting the Haltech EMS because from what I seen, it’s really simple to configure and I can get dual CAN widebands. My local tuner said he was going to give me some pointers on tuning when on the dyno so that was also a plus.
Do you remember how u had the air temp sensor hooked up? I will hook up the probe at where the air leaves the intercooler. Or should I hook it up on the charge pipe right before the TB? As for the wiring, did you get the power from the ecu out or should I run separate 12+ and ground then just the signal to the ecu?
Yea sorry forgot to add that part I'm an HR as well, went with the Dynosty HR/VHR head gaskets. No worries though, best of luck on your setup! It seems a lot of VHR stuff can just be used for our HR's.
Damn that sucks to hear they discontinued it, but I *think* for what it's worth that you can just run a VHR head gasket in the future to get more vendor/product options if you do have to do a do-over. Kinda like how you can run the VHR block with the HR heads kinda thing.
jonnyidfw
Jan 20, 2016 09:12 PM
