css block guards?
Old Jan 22, 2019 | 07:09 PM
Cengineer's Avatar
Cengineer
Default css block guards?
From some simple searches, it seems that the stock sleeves start to oval around 850 whp (vq35de), of course one solution is the darton sleeves
How do the css block guards perform? Some of the Honda guys claim it helps with reliability and is a viable solution (Google search)
Material is 6061 aluminum, so yield strength isn't particularly high however it may prevent this "ovaling" of the stock cylinders at a reasonable power level (950-1000 whp?), due to the tight fitment...
Thanks for your input
Old Jan 22, 2019 | 07:56 PM
BluestreamDE's Avatar
BluestreamDE
Sub'd. Interested in what others have to say.
Old Jan 23, 2019 | 08:13 AM
thatv35guy's Avatar
thatv35guy
If your cylinders are going to oval would a half inch of aluminum at the top of the block really prevent that?
https://cylindersupportsystem.com/
Old Jan 23, 2019 | 09:25 AM
OldManZ350's Avatar
OldManZ350
Their are some guys with VQ's that have had this done by another company , but I've never heard any updates about the Performance.
Old Jan 23, 2019 | 01:41 PM
jdm-v35's Avatar
jdm-v35
seems they are not well liked in other communities such as honda. well at least the cheaper drop in block guards. supposedly they are made of a different metal and expand differently with heat, so they actually cause the cylinder to oval because of that. Essentially those RJM closed deck blocks are just a more precision version of this. They are more precisely cut block guards, with what I am guessing is a metal matched to the block material, and then the top is machines flat.
Old Jan 24, 2019 | 08:41 AM
iideadeyeii's Avatar
iideadeyeii
The cost of swapping to a LS motor and getting that to 1000whp is much MUCH cheaper than trying to make a vq35 reliable with 1000whp. Just my thoughts
Old Jan 24, 2019 | 11:56 AM
Cengineer's Avatar
Cengineer
If it was truly 1/2" dimension with the 30 ksi material then it'll add 15,000 lbf assuming the block does not crack (of course it isn't that straightforward, but it'll add some strength but the question is how much?)
Cengineer's Avatar
Cengineer
If I were to swap I'd go all out and swap in the v10 from the e60
Old Jan 24, 2019 | 01:00 PM
bealljk's Avatar
bealljk
are you aware of B is for Build? He dropped a 10 from an M5 into a 240z...look him up on youtube - sorta an interesting guy...
Old Jan 24, 2019 | 01:03 PM
Cengineer's Avatar
Cengineer
Yeah I watched that build here and there, it came out pretty damn good TBH
Old Jan 24, 2019 | 04:59 PM
knuckles899's Avatar
knuckles899
I think there is a member or two on here running the RJM closed deck blocks.....hopefully they'll chime in on how its holding up. I'm curious on the differences between the 2 companies. CSS looks as if there is a slight recess around the cylinders and RJM looks completely flat all the way across......with absolutely no knowledge of any of this I would think having a completely flat mating surface would be better to utilize clamping force for the head gasket?
CSS VQ block
RJM VQ block
Old Jan 25, 2019 | 02:02 PM
BluestreamDE
I agree that a flat surface is more desirable for a better head to block seal and mating surface. If i was given a choice between the two companies, RJM would get my monies. Not knocking CCS as it looks like a good alternative, perhaps for milder setups. Good info in this thread for what we all know soo far.
Old Jan 25, 2019 | 03:00 PM
OldManZ350's Avatar
OldManZ350
You Guys should have seen the Nasty Filthy Block that my friend ordered from RJM.....
You would think they would start with a nice clear Block and make it look newish before shipping it to a customer.
Darton Sleeve is By Far, The Very Best way to Go for over 900whp
Old Jan 27, 2019 | 11:57 AM
Cengineer's Avatar
Cengineer
I think the reason why this block guard is attractive is because you do not have to machine the block for the darton sleeves (so saves money and is quicker installation) but also because there is a faint promise that the 800-900 whp will be reliable. This figure (I'd argue) is also plenty for most weekend cars
Old Jan 27, 2019 | 12:03 PM
Cengineer's Avatar
Cengineer
Rzg motorsports apperently used these css block guards for two vq35de
"1000 whp rating" and will be proven if it works shortly, I am in contact with one individual who has this install
Old Jan 27, 2019 | 12:51 PM
bealljk's Avatar
bealljk
Cengineer ... I volunteer you to get the block guard and do a full gamit of research, testing, and development and return to us with a full report and results...
that will be all
all joking aside - you should do it, start a thread and become the matter-expert on it.
Old Jan 27, 2019 | 04:14 PM
OldManZ350's Avatar
OldManZ350
In the End, not that much cheaper than Sleeves
Old Jan 27, 2019 | 09:16 PM
knuckles899
I think you can get a whole RJM closed deck block for around $1400-$1700.....sleeves alone are around $1200.... and a whole Mazworx darton sleeved block is $2800 seen here Mazworx darton block. I keep getting pulled back and forth as far as what direction to take with my engine build.....very reputable shops telling me to keep it simple and do pistons and rods only due to them seeing issues with the darton sleeves not being properly installed/machined causing multiple problems.....then hearing the exact opposite with no problems with the closed deck blocks offered by RJM and CSS. Basically I'm about to spend another $8500-$10000 for someone to build a complete longblock assembly for me and I don't want to get burned.........I just don't know what direction to take on all this.
Old Jan 27, 2019 | 10:17 PM
OldManZ350's Avatar
OldManZ350
I hear You!
What kind of Power are you looking for? Just for Street or?
I have a few friends WITHOUT Sleeves or a closed deck that do just fine. And they beat on their motors Hard to 8000rpm. In the 700-800+ WHP
Unless you are planning on making more than that, then a stock block is just fine. As long as it's put together Correctly......
Old Jan 28, 2019 | 10:39 AM
knuckles899
Shooting for 650whp hopefully using 91oct low boost and 750-800whp hi boost using e85 or high oct race fuel. Fueling will utilize CJM S3 kit twin pump......was told by CJM new twin pump should be available around March or April. Haven’t determined injectors yet. Trying to keep it all tuned with Uprev as I sold my Haltec EMS.
I plan on doing the Shift S3ctor air strip roll racing events but will still drive it on the street occasionally. Currently running the 350z HR BP single turbo kit 11psi 440whp stock block on a mustang dyno but have ran it a dozen times at 14.5 psi 104 oct so unsure on how much more HP there was. All supporting mods done clutch,wheels,tires,brakes etc etc.
I hear You!
