Garrett GT3582r with .82 turbine housing, Tilton Oil Scavenge Pump and Oil lines
I bought this turbo from these forums about a year ago with intentions of upgrading my APS Single turbo. Well that never happened, and this turbo is gathering dust in my basement. Hopefully someone here can put it to better use. I did get fittings for the oil (-10) and water (-6). They will be included, but you might still want to get your own. Theres a -10AN straight and a banjo fitting. I will also include the outlet flange with hardware and the mishimoto 90 cold side outlet hose.
The Tilton pump is un-used. I unboxed it and mocked it up but I decided to just go with the same type that came with the APS turbo kit. I have -10 fittings for the inlet and outlet with one -10 straight and two -10 90 hose fittings.
Looking for $600 for the turbo and $150 for the pump.
Reason: Sold the hoses
