Piston to wall clearance? .0065 too much?
Old Jan 2, 2020 | 09:32 AM
jdm-v35's Avatar
jdm-v35
Default Piston to wall clearance? .0065 too much?
My build has been going slowly, but I currently have a block at the machine shop. It is a sleeved block with Arias pistons made from 2618. After the hone they said they will end up at .0065" piston to wall clearance. The machine shop said it would run, but they recommend new pistons. I was wondering if this much clearance would be ok in a boosted application, giving room for heat expansion? or should I just order the new pistons?
Would appreciate any advice from experienced builders.
Old Jan 2, 2020 | 11:29 AM
OldManZ350's Avatar
OldManZ350
This might Help!
Also, Piston Manufacture has Clearance Specs, use those.......
File Type: pdf
Old Jan 2, 2020 | 01:31 PM
jdm-v35's Avatar
jdm-v35
thanks! I will probably end up ordering new pistons to do it right.
MR RIZK
May 3, 2010 01:24 AM
djtimodj
Oct 2, 2009 10:26 AM
TheMinel
Jul 7, 2009 11:31 AM
sash86
Mar 16, 2009 08:47 PM
Z350Lover
Nov 6, 2005 12:43 PM
