Vortech V2 Hard Starting hot
Old May 1, 2020 | 01:21 AM
John-Paul Grigg's Avatar
John-Paul Grigg
Default Vortech V2 Hard Starting hot
Hi guys, my 350z will start just fine from cold cranking, but it will take forever or not start at all when it is hot, or has been standing for a few minutes after driving....E.g going into shops, or fuelling the car.
Is this a tuning issue, fuel mix too rich for hot engine restart???
I have the original Utec Turboxs piggyback ECU running it, any ideas where/how to correct for this heat sink? I'm sick of leaving the car for an hour or so, waiting for it too cool so I can start it again, or cranking it till the battery dies and I'm left stranded.
Any help would be great.
Cheers
Old May 1, 2020 | 06:52 AM
jhc's Avatar
jhc
General & Tech Moderator
Not to overstate the obvious but you should check the resistance on your coolant temperature sender when warmed up. If resistance is either 0 or infinity the sender is bad.
If the sender is good, trouble shoot like it was N/A. Air filters clean, injectors serviced?
vqlife9212
Sep 19, 2018 05:12 AM
charged
Aug 7, 2013 08:38 AM
whitez33350ztt
May 4, 2010 09:18 AM
Nexx
Jun 30, 2007 01:53 PM
Sisith
Mar 21, 2007 06:50 PM
