VQ Engine Specs needed
Old Feb 25, 2004 | 12:01 PM
g356gear's Avatar
g356gear
Default VQ Engine Specs needed
Does anyone have the following specs at hand? Thanks.
1. Bore measurement
2. Stroke measurement
3. Cylinder head chamber volume (cc's)
4. Piston height below block deck
5. Stock head gasket thickness
Old Feb 25, 2004 | 01:43 PM
etx's Avatar
etx
Bore: 95.5 mm (3.76 in)
Stroke: 81.4 mm (3.205 in)
I gotta run, all the other info you need should be in this file.
http://www.etherealdesign.com/pics/350z/em.pdf
Old Feb 25, 2004 | 02:06 PM
g356gear's Avatar
g356gear
Thanks etx for the link... can't seem to find any info on the head gasket thickness or deck height but I guess i can get that from my spare motor when I pull the heads.
Can't find stock head cc volume though
Old Feb 26, 2004 | 08:21 AM
azrael's Avatar
azrael
ask SGP, I'm sure they know all these details -- this is all the info you'd need to know to build lower compression pistons, which they have done.
Old Feb 27, 2004 | 05:27 AM
g356gear's Avatar
g356gear
Bore 3.76"
Stroke 3.205"
Stock cylinder head chamber volume 56cc
Stock head gasket thickness 0.025"
Thanks Nathan !!
bcoffee20
Nov 19, 2015 06:39 PM
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
