Bad news for the big boosters...!
Old Mar 10, 2004 | 08:49 AM
  #61
JeffesonM's Avatar
JeffesonM
Originally posted by SKiDaZZLe
don:
the Z ecu interprets 5v as 33.827 pounds/min of incoming air..
this is the limit... doesnt matter what MAF you put there, if its calibrated to what the ECU wants to see.
as an example: get a MAF that outputs 1/2 the voltage as stock... then when there is 33.827 pounds/min, the ecu will only see 2.5v.
Now the ecu will only add fuel for 16.9 pounds/min of air...
see the problem..?
the only solution I see is getting injectors with double the output... this way the air/fuel ratio will work itself out!
Some maxima guys are using a Z32 MAF and 370cc Z32 injectors with the stock ECU. The readings from the Z32 MAF are ~49% lower, and the 370cc injectors provide around ~54% more fuel, so it effectively works it self out as you said. To fine tune they use a FMU with small ratio disc and lean it out with a SAFC.
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
Cashwin
Oct 1, 2015 06:36 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
