vq35de build
Old Feb 2, 2025 | 10:42 AM
NewToVqPlatform's Avatar
NewToVqPlatform
Default vq35de build
Hey, I’ve been doing a few research about building vq35de, I want to add a turbo kit (still hasnt done some research so if you have any suggestions please lmk). Anyways here is a list of the components i chose. my hp goal is 500-600.
PISTONS/RODS https://conceptzperformance.com/wise...bpH2770gqa88AV
Head gaskets
https://conceptzperformance.com/hks-...VVOb-8_0g3CZ4P
Head studs
https://conceptzperformance.com/arp-...uPF2qXK72cqpa5
Main studs
https://conceptzperformance.com/arp-...ziXMeZlfRoaSU7
Rod/main bearings/thrust washers
https://conceptzperformance.com/acl-..._juYYU-1kpuX_b
Clevite CB-1857P connecting rods bearing set
https://conceptzperformance.com/clev...kt_p_11015.php
nissan oem main bolt kit
https://conceptzperformance.com/niss...3C0zxScqZ9XU-H
Nissan internals (gaskets)
https://conceptzperformance.com/ishi...41_p_29044.php
Nissan OEM Juke Cylinder Head Bolt Kit
https://conceptzperformance.com/niss...gacCbmBFSU1gRz
Jwt cams/springs
https://conceptzperformance.com/jim-..._K3gc_35Gg1GQU
valve stem seals
https://conceptzperformance.com/gsc-...meFVOHJSjUyO5U
Oil pump « revup »
https://conceptzperformance.com/niss...RvW-saNxL2yMmQ
Timing kit 350z
https://conceptzperformance.com/standard-oe-type-timing-chain-kit-vq35de-nissan-350z-infiniti-g35-c-z33-tc-kt-2_p_28037.php?srsltid=AfmBOoqRW3G21o6PFozVeplzCgaBv81A0W0Tza dCkGQ9L2JAQGcW568q
Please lmk if anything is missing, or if I should replace what I chose. I dont have a budget but im not looking to spend more than 7-8k on the engine rebuild
Old Feb 2, 2025 | 01:14 PM
bealljk's Avatar
bealljk
You wont need both the ARP head studs and the Juke Headbolts, nor the ARP Main Stud Kit and the OEM Main Bolts … those are essentially the same thing … just go with the ARP main studs and head studs. Consider going with ARP L19 head studs … anything over 500hp you want the L19s.
Consider Brian Crower springs too - JWT has had some quality control issues and guys have broke spring and ruined builds. Are you going to upgrade your cams while youre this far in to it?
Alot of guys go with Dynosty head gaskets as many VHR guys have had great success with them
Add the Dynosty Main Girdle too
The RevUp pump would be fine but the upgraded solution from there is the Boundary Oil Pump gears or the whole assembly
Old Mar 16, 2025 | 02:00 PM
wzrdstrm's Avatar
wzrdstrm
5 Year Member
what do you do with the Dynosty Main girdle? Not familiar with this. Cam shafts....not building a FI...yet, recommend for NA?
Old Mar 18, 2025 | 12:22 PM
bealljk's Avatar
bealljk
Repalces the OEM main girdle - helps stabilize the mains.
Old Mar 18, 2025 | 03:10 PM
iideadeyeii's Avatar
iideadeyeii
Go big or go home
https://www.mazworx.com/pro-street-b...5de-block.aspx
blimon63
Nov 27, 2014 08:09 AM
tchuck
Nov 20, 2013 10:36 AM
SniperHunter
Nov 2, 2007 04:47 PM
