Vortech SplitSecond Box Question
Old Mar 9, 2004 | 03:51 AM
fluidz's Avatar
fluidz
Default Vortech SplitSecond Box Question
Does the split second box do anything else other than retard timing? Can you adjust A/F ratios in the box.........and will the stock ECU relearn its original settings after a period of time and overide the SS box?
Old Mar 9, 2004 | 04:51 AM
blubyu's Avatar
blubyu
Default Re: Vortech SplitSecond Box Question
So far from what I've seen the stock ECU will not overide the SS box. I have seen 2 G35's tuned with the SS box and the settings are still the same and haven't reset themselves. I know for a fact its a timing control unit and I believe it is a form of fuel control also but not for certain. Check with Zimbo or dollar99 those are the two cars I have personally seen tuned.
Old Mar 9, 2004 | 04:56 AM
jesseenglish's Avatar
jesseenglish
I don't how how it could be a fuel control because the Vortech uses a Mechanical FMU to increase fuel pressure to the injectors. Maybe it does something similar to the SAFC-II, where it can adjust MAF voltage to increase or decrease injector pulsewidth. Other than that I don't see it.
Old Mar 9, 2004 | 05:15 AM
fluidz's Avatar
fluidz
so if the Vortech FMU is mechanical it must read when to increase fuel pressure off the stock MAFS, what happens when the stock ECU relearns and goes back to original settings, wont it run lean?
I heard from a tech that the 350Z has a adaptive learning ECU and it has multiple maps to where it can go to learn its original settings?????......unless the vortech mechanical fmu reads off boost pressure? but it still would be kinda messed up if the MAFS was after the superchager, it seems to me if the 350Z does have a relearning ecu then the MAFS must be located before the supercharger and the Vortech FMU must be based on its own boost and not the 350z MAFS at all.
Old Mar 9, 2004 | 05:30 AM
jesseenglish
The mechanical FMU adjusts fuel pressure based on boost.
Old Mar 9, 2004 | 05:41 AM
fluidz's Avatar
fluidz
THE ati DOES NOT ADJUST ON BOOST RIGHT, JUST OFF THE AEROMOTIVE BOX?
Old Mar 9, 2004 | 05:45 AM
jesseenglish
The Aeromotive box that comes with the ATI kit adjusts fuel pressure based on boost. It supplies a varying voltage (based on boost) to an aux fuel pump that raises fuel pressure.
Old Mar 9, 2004 | 05:53 AM
fluidz's Avatar
fluidz
ISNT THE STOCK ecu GOING TO WANT TO ADD MORE FUEL AS WELL WHEN IT READS THE EXTRA AIR COMING IN, THUS MAKING IT RICH.....and what happens if you have it tuned and leaned out a bit and a month later the ecu releans and goes back to original settings......wont you be lean? Sounds like this could be a BIG problem if infact the stock 350Z ECU has re-learning ability, I have a feeling that is why a few cars have blown up. I heard Vortech kits where very rich when they first where installed, anybody ever go down a month later to see if they did infact lean out a bit due to the ECU going back to original settings? Am I all messed up in my thinking or what??????
Old Mar 9, 2004 | 06:45 AM
etx's Avatar
etx
Rising rate FPR's are the worst possible way to tune any FI system.
Old Mar 9, 2004 | 06:49 AM
ravaz's Avatar
ravaz
Man the whole "relearning" thing the ECU does is BS. If that's the case, then I'd be f*cked right now. I ride around with a wideband O2 all day, and any adjustments I made with the DFMU that comes with the ATI kit, and whatever I changed with the SAFC would have gone to sh*t. It hasn't, my #'s are the same and will stay the same, period.
Old Mar 9, 2004 | 07:29 AM
fluidz's Avatar
fluidz
how long and how many miles have you put on your car since fuc*king with it? Be honest...
Old Mar 9, 2004 | 09:12 AM
ravaz's Avatar
ravaz
In all honesty, about 4200 miles, driving it really hard.
Old Mar 10, 2004 | 12:06 AM
elektrik_juggernaut's Avatar
elektrik_juggernaut
your introducing an entirely tandem fuel system into the existing fuel system........the stock ECM "sees" the AFRs with a narrowband..........when your at WOT or anywhere above the point where the MAF goes to max then you're in open loop, and no adaptation will be taking place while in open loop......if the tandem fuel system is set up for a fairly stoich mixture then the narrowband O2's aren't going to be seeing too much more added fuel anyway while in closed loop.......assuming all the other components are working properly
in the stock ECM fuel maps and timing maps there are changes that occur as RPMs rise......the timing changes are the critical ones that will pop your block, but the fuel changes can do it too, if the tandem fuel system is set up initially too lean
the ECM does adapt, if it didn't the SAFC wouldn't work.....it "tricks" the ECM into making the adaptations when you want it to make them
Old Mar 10, 2004 | 07:16 AM
zimbo's Avatar
zimbo
From the SplitSec website:
The FTC1 Fuel/Timing Calibrator provides precise calibration of fuel and timing retard. It is most often used when naturally aspirated engines are converted to forced induction. The fuel calibration range supports conversion to larger injectors. The timing control section is used to map timing retard to avoid detonation under boost.
Through a serial interface, the FTC1 can be programmed by a laptop computer running the Split Second R4 software. The software provides three dimensional mapping of the MAP and timing retard signal. The MAP value output is determined by the active cell value. The active cell is determined by absolute pressure measured by the internal sensor and RPM.
--Steve
Old Mar 10, 2004 | 09:36 AM
STR8OUT's Avatar
STR8OUT
So the Vortech does come with the Fuel/Timing box?
If so, then awesome. I am used to tuning a Utec on my WRX so this should be almost the same I am guessing. Time to get out the wideband.
Old Mar 11, 2004 | 08:33 PM
fluidz's Avatar
fluidz
so zimbo, how is your car running and did you adjust A/F through the split sec box? after driving it for awhile has ur A/F changed at all?
Old Mar 12, 2004 | 03:25 AM
zimbo's Avatar
zimbo
As long as the car is fully warmed up and the belts are properly tensioned, the A/F programming seems to not require constant changing unless you make intake or exhaust changes.
My car has been running well... but I decided to add high flow cats and Crawford plenum which I knew would require me to add some more fuel to the R4 maps, which I did. I haven't had time to dial it in really well yet so right now I'm running a bit too rich between 4500 and 6000 rpms.
I'm getting belt squeal (which is normal as the belt expands a bit after initial installation) but it appears that the tensioner is already as tight as it can go so I need to call Vortech.
--Steve
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
