greddy twin turbo guys oil in exhaust
Old Mar 29, 2004 | 11:38 AM
pimpjuice's Avatar
pimpjuice
Originally posted by g356gear
There is a ring at the top of the tube that goes down around the spark plug. It is part of the valve cover assembly...it's most likely leaking at the top. Have you had the valve covers off the motor?
Nope, just switched out the spark plugs. I am confused about the ring you are talking about though. The tube that goes around the spark plug itself is part of the coil pack and the coil pack seals the exterior of the chamber at the top. This would have nothing to do with oil leaking into the spark plug chamber.
Old Mar 29, 2004 | 11:45 AM
pimpjuice's Avatar
pimpjuice
Originally posted by 03_ppw350z
1 more thing that i have learned. greddy told me to unplug the hose that goes to the air inlet on the drivers side you know the one that connects to the valve cover well after some runs with it dangling there oil comes out of that hose. could it be that we have to much crank case pressure? maybee a breather would help at teh oil fill point. just some thoughts to add in this gets very annoying to me! the car runs bad *** though i already trapped 115 at 6psi
You are correct, but oil will still come out through the filter. The only way I can think of eliminating the problem is to use a greddy catch can. You would connect one end to the crank case and the other to the non-pressurized side of the turbo(s) (the vacuum, or intake side).
Old Mar 29, 2004 | 11:47 AM
03_ppw350z's Avatar
03_ppw350z
while this was unplugged it still had the oil problem so if i put a catch can in that spot the oil will still burn the way it is the hose was dangling in the spot the catchcan would be
Old Mar 29, 2004 | 11:51 AM
pimpjuice's Avatar
pimpjuice
Sorry, I thought you meant you were getting frustrated with oil coming out of the hose. The greddy catch can would catch the oil spilling out, but no, it won't keep you from burning oil.
Old Mar 29, 2004 | 01:31 PM
etx's Avatar
etx
Hrm. So oil is coming through the PCV/Breather inlet? Does the Z have a check valve to prevent the pressure from the mani under boost? I can't find anything about a PCV valve in the FSM. I didn't really take a good look at the pcv plumbing, ill check it out when I get home. Perhaps a check valve that seals up better under pressure would help.
The smoke from my Z is black, an excess of fuel. It only does it right after the throttle plate closes.
Old Mar 29, 2004 | 02:14 PM
g356gear's Avatar
g356gear
There is a metal tube that goes all the way up through the cylinder head almost to the top of the valve cover. At the top is a rubber ring that seals this tube as it passes through the valve cover. If this is cracked the oil would come over the top of the tube and down around the plastic coil assembly to the sparkplug.
Old Mar 29, 2004 | 02:33 PM
pimpjuice's Avatar
pimpjuice
Gotcha. Makes perfect sense now.
How hard is it to replace this ring?
Old Mar 29, 2004 | 05:27 PM
03_ppw350z's Avatar
03_ppw350z
i pulled the pcv valve capped where it goes in to the intake and let the one from thae valve cover dangle. what this means there is no way to get oil in to the intake but it still does it! this is so fustrating maybee it is skoe from exess fuelk but it sure does smell like oil? i dont think its bad turbos either becuase for 1 they are brand new 2nd it has done this since day 1 and third it doenst smoke at idle under throttle or anything only when you let off for 2-3 seconds max!
Old Mar 30, 2004 | 12:44 AM
03_ppw350z's Avatar
03_ppw350z
how do you keep the blow off from opening do i jus unplu vacume hoe from it? i want to disable the blowoff to see if it still does it. mybee its to close to the maf like you said and is cuasing it to freak out
Old Mar 30, 2004 | 07:10 AM
etx's Avatar
etx
That depends on your BOV. If you just disconnect the signal line it will probably just leak because there will be no signal, or pressure to hold it shut.
Old Mar 30, 2004 | 09:21 AM
03_ppw350z's Avatar
03_ppw350z
damn i will just cut another elbo for temp use to bypass the valve for my little test!
Old Mar 30, 2004 | 11:27 AM
etx's Avatar
etx
Yeah let me know how it works out. I think I am going to try a few things as well, but it's supposed to rain all week here so the Z won't be leaving the garage for a while.
Old Mar 30, 2004 | 11:39 AM
g356gear's Avatar
g356gear
You have to pull off the valvecover...the ring is attached to the underside.
Old Mar 30, 2004 | 01:28 PM
03_ppw350z's Avatar
03_ppw350z
ok i think i can jus tighten the blowoff valve althe way down so it doesnt open that should work to keep it shut
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
kyin
Oct 15, 2015 05:54 AM
