Fuel Pump?
Old Mar 17, 2004 | 07:54 AM
POPA 350z's Avatar
POPA 350z
Default Fuel Pump?
I got recently my Greddy TT Kit. I'm getting the final stuff to install.
My question is those who have alreday their TT Kit?
Did you guys kept your stock fuel pump?
Did You replace it ?
What pump are you using if replaced?
Old Mar 17, 2004 | 08:50 AM
Yancy's Avatar
Yancy
Replaced because it could not supply enough fuel under boost. Walbro 255LPH high flow fuel pump. Costs around $125-150.
Old Mar 18, 2004 | 05:41 PM
m3powerrr's Avatar
m3powerrr
Hey Yancy, did you replace the fuel regulator also? So are you running higher boosts now? thanks
Old Mar 19, 2004 | 05:27 AM
POPA 350z's Avatar
POPA 350z
Where did you get the fuel pump from? Because all I found is inline, but I'm looking for a Intank
Old Mar 19, 2004 | 06:24 AM
Yancy's Avatar
Yancy
Not sure if installer replaced regulator or not. I'll have to check. My installer (Godspeed Inc in Novi, MI www.godspeedinc.com) got the pump and installed it. I'm running 6.5 and 8.0 psi settings.
kyin
Oct 15, 2015 05:54 AM
