sync e-01 with aem wideband?
Old Apr 9, 2004 | 08:05 PM
jesseenglish's Avatar
jesseenglish
Originally posted by gq_model_626
Either way, I running MUCH richer than my tailpipe dyno measurement indicated. It showed me gradually maxing out at 11.4
Just curious, does the AEM wideband unit provide a free air calibration? The reason I ask is because your O2 sensor should be calibrated to your particular elevation. Perhaps it's an automatic calibration, but I was just curious about this.
Old Apr 9, 2004 | 08:14 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Here is the quote from the AEM A/F instruction booklet:
"Each AEM UEGO sensor is individually calibrated and a resistor integral at the connector body is laser trimmed with this value. This process replaces the traditional "free air" calibration when changing sensors and implements a sensor specific calibration for unparalleled accuracy."
So I guess the answer to your question is "no".
Old Apr 9, 2004 | 08:22 PM
jesseenglish
Aaah, I see thanks. I didn't think they'd forget about something like that. Just didn't know how they did it.
Old Apr 9, 2004 | 08:24 PM
Sharif@Forged
Forged Performance
Ok, after studying the manual, I see that the guage has a measurable range of 11.00 to 16.75. So when I am WOT, I am definately under 11.00 which is why it's not registering a value.
Old Apr 9, 2004 | 08:32 PM
jesseenglish
The Techedge wideband measures from 9:1 - 18:1
Old Apr 9, 2004 | 08:50 PM
Sharif@Forged
Forged Performance
Ahh...I wish I knew that before spending $400 on this thing.
Old Apr 9, 2004 | 08:53 PM
jesseenglish
Your display is nicer if that makes you feel any better.
Seriously, I've mentioned it on numerous threads, but the Techedge is the best bang for the buck wideband available as long as you can put up with the display.
Oh and a correction, the Techedge will actually measure and display from 8:1 - 45:1 A/F ratio, but the voltage out for an aux engine management system is only 9:1 - 18:1
Old Apr 9, 2004 | 09:08 PM
Sharif@Forged
Forged Performance
Yeah...I guess you are right. Also, once properly tuned, F/I cars shouldnt be running richer than 11:1
Old Apr 9, 2004 | 09:19 PM
jesseenglish
Unless you like the smell of your cats burning up.
Old Apr 9, 2004 | 10:02 PM
Sharif@Forged
Forged Performance
I prefer my cats medium-well.
Old Apr 9, 2004 | 10:08 PM
Sharif@Forged
Forged Performance
Default Calibration
o3_ppw
I found another calibration table in the instruction manual. not sure which on is correct. so if the one I posted is not accurate, the use this conversion factor. Lemme know which one ends up working.
.5 Volts equal 11.00:1
3.375 Volts equals 16.75:1
Workshop12
Mar 23, 2020 01:45 PM
350Shadow
Sep 22, 2015 08:30 AM
Calinismo350z
Sep 14, 2015 04:04 PM
