How to copy original map on SS Box?
Old Apr 9, 2004 | 03:03 PM
fluidz's Avatar
fluidz
Default How to copy original map on SS Box?
just want to see whats there.
Old Apr 9, 2004 | 03:04 PM
baptist's Avatar
baptist
Fluidz,
I've not even got my kit yet, but I have the software and have had a play around with it.
Do you mean that you want to make a copy of the original map that you have now? and keep it for safekeeping??
Old Apr 9, 2004 | 03:20 PM
fluidz's Avatar
fluidz
Originally posted by baptist
Fluidz,
yes mainly just to see what vortech set everything at
Old Apr 9, 2004 | 03:23 PM
baptist's Avatar
baptist
Fluidz, you have PM.
Old Apr 9, 2004 | 07:32 PM
zimbo's Avatar
zimbo
Fluidz, you probably know this by now but you do the following:
(1) Choose File | New Customer and give it a file name
(2) You then choose File | Open Customer and choose the file you specified in step 1
(3) Choose the correct COM port and click the Connect to ECU button
(4) Click Maps | Fuel maps from the menu
(5) Click the Load from ECU button on the Fuel map screen.
(6) Close the fuel map window and Exit the program
(7) Make a backup copy of the MDB file
HTH.
--Steve
Old Apr 9, 2004 | 09:02 PM
fluidz's Avatar
fluidz
got it , will post in a sec
Old Apr 10, 2004 | 09:03 AM
350zer's Avatar
350zer
HTH.
--Steve
before you down load maps you must set the settings. if you don't it won't down load them. go to options engine 6 cyl. 4 str. then to settings. vacuum/ pressure programmable signal cal. is what you want. after you have done this know you can down load the maps. it will down load the rest once you do these settings.
Old Apr 11, 2004 | 09:33 AM
fluidz's Avatar
fluidz
why programmable signal calibrator and not additional injector controller?
Old Apr 12, 2004 | 07:32 AM
350zer's Avatar
350zer
injector controller is for controlling additional injectors. ss makes alot of diffirent stuff and r4 is the software for all of it. so some of the setting have nothing to do with what we are doing.
Old Apr 12, 2004 | 08:53 AM
fluidz's Avatar
fluidz
why was mine set to Adjustable injector controller from VORTECH? Zimbo runs the same setting........please explain.
Old Apr 12, 2004 | 09:23 AM
tig488's Avatar
tig488
mine too
Old Apr 12, 2004 | 10:46 AM
350zer's Avatar
350zer
Originally posted by tig488
mine too
because that is the defaut setting.
Old Apr 12, 2004 | 10:53 AM
fluidz's Avatar
fluidz
why would i change it, my car runs great with that setting?
Old Apr 12, 2004 | 10:58 AM
350zer's Avatar
350zer
you would'nt. the box is not set to that. it comes up that way because you did'nt down load it right.
Old Apr 12, 2004 | 11:02 AM
fluidz's Avatar
fluidz
are you saying that the vortech map is set to Pressure/vacuum, etc in the box from vortech, and when i upload it under new file name that if i dont set the settings to what you said it will default my settings to adjustable injector, etc? If so how do you know this info just out of curiosity.
Old Apr 12, 2004 | 11:10 AM
350zer's Avatar
350zer
so your saying my box isnt right even though it runs great and zimbos is wrong as well and he is at 370rwhp........if you could explain ur reasoning then I'd listen but you have no good explaination for why to change it.
because mark at ss walked me through the software and all the settings. he is the owner and creater of the box. i have spend at least an hour on the phone with him as he helped me out. why don't you call me so i can explain in detail to you.
Old Apr 12, 2004 | 11:14 AM
fluidz's Avatar
fluidz
I think I will call them right now to be sure what you are saying is true.
Old Apr 12, 2004 | 11:33 AM
tig488's Avatar
tig488
i just hung up with them, im gonna try some things, they tend the think my #s are too high causing the MAF to get too high of a signal and shut off.
Old Apr 12, 2004 | 11:43 AM
fluidz's Avatar
fluidz
what numbers are to high? A/F?
Old Apr 12, 2004 | 01:38 PM
tig488's Avatar
tig488
no, the fuel map #s
