Stillen Stage 3 Dyno Numbers
Old Apr 27, 2004 | 02:12 PM
2003z's Avatar
2003z
Traction isn't really a problem, just need to get the right tires (drag slicks for drag and race rubber for the track) and/or learn to feather the throttle. ITs great to not have to downshift from 6th to pass someone on a 2 lane road. With the stillen, the car really does behave just like stock, just with a lot more oomph.
also, after 30 minutes on the racetrack, no heat problems at all, and the intake felt no hotter than non supercharged to me.
Old Apr 27, 2004 | 04:54 PM
aggie300zx's Avatar
aggie300zx
Thanks 2003z for the heat response...those are the kind of points that are important to know about. On that note, does it make any difference to have the stock air box vs. the JWT popcharger??
Old Apr 28, 2004 | 09:30 AM
2003z's Avatar
2003z
I believe stillen recommends the stock airbox due to an open filter getting very noisy. Dont know about performance wise though.
Old May 5, 2004 | 08:02 AM
jkoc's Avatar
jkoc
the magazine also states that the stillen SC never showed signs of detonation whereas the other two did suffer from it.
fairly important tidbit of info imo
Old Aug 23, 2004 | 04:03 AM
kyle sinclair's Avatar
kyle sinclair
I was wondering if I could maybe get some 0-60 times and some 1/4 mile times from you. Also, just wondering if those dyno numbers are based on a stock engine without exhaust, headers, etc. What is the max psi??
Old Aug 24, 2004 | 03:45 AM
Zoomy_1's Avatar
Zoomy_1
The heat produced by roots type S/C should be no worse than anything else. The heat is cause by compressing air. Therefore more boost more heat. You want hot run a 18 PSI F/I system. The Vortech on my Firebird would melt anything plastic on the way to the after-cooler. Found that one out the hard way. For max out put I would spray No2 into the cooler.....good for A TON of power. Of couse there was nearly over 6 liters of motor to make the power though.
Old Aug 26, 2004 | 10:47 AM
Zmeflyby's Avatar
Zmeflyby
really......
i didnt know that
well atleast stillen actually has something good out for us
Old Aug 27, 2004 | 08:05 AM
bldrz's Avatar
bldrz
we have been running the stillen s/c on our first project z for awhile now. the unit appears to be very reliable and even with a custom built pulley the stillen box adjusted the a/f to a safe level. for the occasional trackday/everyday driver i believe this unit is one of the best available. however if hp/tq is your goal the only way to go imho is a twin turbo setup.-jason
Old Aug 27, 2004 | 10:50 AM
2003z's Avatar
2003z
bldrz, what pulley did you make, and are they for sale? details plz.
Old Aug 27, 2004 | 11:30 AM
bldrz's Avatar
bldrz
2003z, we built a 12 pound billet pulley but we should be able to fabricate a pulley for less boost. pm me if interested.thanks jason
Old Aug 27, 2004 | 03:49 PM
bigern1970's Avatar
bigern1970
Default Re: Stillen Stage 3 Dyno Numbers
Originally posted by 2FST4U
These are the numbers from the Dyno Shoot Out that we performed with Sport Z Magazine. Please note that these numbers are straight off of the dyno charts. The dyno charts get a bit messy to read when all of the lines cross each other. So, this should help. You can see from this that if you are looking for everyday driving performance in normal RPM ranges - which system provides the best performance. If you are drag racing with gears that allow you to operate at very high rpms, or like the peak gains, then the other units will be of interest to you. They each have their merits.
..............Baseline........Stillen @ 7psi......Prochgr @ 7psi.....Vortec @ 8psi
RPM.......HP/Torque.........Hp/Torque..........Hp/Torque..........Hp/Torque...........RPM
6500......228 / 187...........325 / 264...........350 / 281..........335 / 272............6500
6000......240 / 210...........320 / 280...........338 / 296..........328 / 287............6000
5500......238 / 227...........308 / 292...........312 / 294..........298 / 283............5500
5000......223 / 234...........288 / 302...........282 / 298..........268 / 281............5000
4500......204 / 238...........258 / 299...........248 / 287..........245 / 284............4500
4000......176 / 232...........228 / 300...........212 / 280..........212 / 277............4000
3500......152 / 229...........199 / 297...........178 / 268..........178 / 267............3500
3000......130 / 228...........168 / 293...........148 / 256..........144 / 252............3000
2500......105 / 221...........135 / 285...........115 / 239..........111 / 237............2500
2200.......90 / 218............118 / 282..........100 / 234............97 / 234............2200
Reported peak horsepower and torque values:
Baseline:....242.5 hp @ 5800 rpm 239.4 ft/lbs @ 4600 rpm
Stillen:.......338.2 hp @ 6600 rpm 302.6 ft/lbs @ 4200 rpm
Prochgr:.....353.7 hp @ 6600 rpm 300.5 ft/lbs @ 4800 rpm
Vortec:.......344.8 hp @ 6300 rpm 298.7 ft/lbs @ 5900 rpm
Also, please remember that while these results are posted, each vehicle will vary to a certain extent due to OE manufacturer differences, dynos and production tolerances. These run with Carl Merrit of Sport Z Magazine driving each car on the dyno. Same day.
Hope this helps decipher the gains for these systems. The question is where do you want to experience the gains.
While Im sure this post comes in pro stillen, the thread came off to me as being non biased , The chart tells it all, if you want top end the vortech or ati is not the way, I like real world driving , I know ALL these system including TT have will have their issues, I think this one of the more honest threads, and while Im still leaning toward VT myself, thanks for the post, I may still consider the stillen.......and while not to jack the thread will the stillen void my 75k extended warranty?
Old Sep 6, 2004 | 11:33 AM
AZ350Z's Avatar
AZ350Z
Default Stillen Unit-Polished
Does anyone have any good pics of the polished unit?
For my money, this is the unit to go with. What was graciously unsaid in the original post is that the Stillen unit is the only one out there that hasn't been blowing motors left and right. Add the fact that you can get a warranty into the equation and you have a clear winner.
Anyone spraying with a Stillen set-up?
Old Apr 9, 2013 | 11:57 AM
bewsted's Avatar
bewsted
Default Stillen Stage 3 Supercharger
Thanks for posting those statistics.
I have the Stillen supercharger Stage 3 installed, and made 403 FWHP and 350.5 RWHP on my 2003 350Z. Met and spoke to Kyle Millen (Steve Millen's son), and was informed that their SC products are mean to work with Nissan stock internals...which was a relief as I didn't want to overhaul the engine internals just yet.
I have to admit, I don't abuse the car much, roads too crowded when I am on them. Which is also the reason I opted for the Stillen SC, because I want the quick boost off the line. Plus, it's my daily driven car so I can't really spend a lot of time at tune shops and tweaking it.
I don't know why others are getting lower numbers I just do regular oil changes at 3-5K and add in BG oil/fuel additives.
Attached Thumbnails Stillen Stage 3 Dyno Numbers-westlanedynotuning.jpg   Stillen Stage 3 Dyno Numbers-aug2012nissancarshow_enginebay.jpg   Stillen Stage 3 Dyno Numbers-photo-7-.jpg   Stillen Stage 3 Dyno Numbers-photo_blackedge.jpg
Old Apr 9, 2013 | 12:44 PM
bmyles's Avatar
bmyles
I commend you for bumping 9 year old thread. The OP's last activity was back in May of '04. Anyways, good job on the power, but my opinion is lose the wheels and maybe the wing...
Old Apr 9, 2013 | 01:04 PM
Resmarted's Avatar
Resmarted
Approaching a 9 year bump.
Is that a record?
The wing, wheels, hood, side skirts... tail lights... front bumper...
All bleh.
Sell that kit and get a vortech, and get a regular hood, amuse front and nismo sides. Ditch the wing get a evo-r rear wing and pick up some enkies or volks or even rotas.
Old Apr 9, 2013 | 04:42 PM
djamps's Avatar
djamps
Thread delete plz
Old Apr 9, 2013 | 06:48 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Nobody gives two Fawks about the Stillen kit.
With all the options in this market, any owner of a Stillen kit gets the respect of a bukkake ***** with 10 loads on her face.
Old Apr 9, 2013 | 11:48 PM
  #38
midz350's Avatar
midz350
403 FWHP and 350.5 RWHP!!!
Old Apr 10, 2013 | 12:55 AM
  #39
Drako_MDx's Avatar
Drako_MDx
HOLY GRAVE DIGGING!!! This has to be a freakin record... LMFnAO
Old Apr 10, 2013 | 06:53 AM
  #40
djamps's Avatar
djamps
flywheel horsepower. with stillen kit you use that number instead
