Greddy Ignition Timing Harness DONE! Pics
Old May 7, 2004 | 08:57 AM
350Now's Avatar
350Now
I better start looking for the diodes...
Old May 7, 2004 | 09:48 AM
derek_i's Avatar
derek_i
5th store and no diodes... The lady was nice enough to pull out a list of other Radio Shacks and start calling. On the 4th store (not including the 5 I've already tried), we found some and they are holding them for me. And it's only a 1.5hr drive
Do yourself a favor and get a list of local stores from radioshack.com and call ahead.
Part #276-1141
Diode 1N5400
Ask what shape they are, the old style is spherical, the newer ones are cylindrical (get the newer ones)
-D
Old May 7, 2004 | 10:16 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
LOL...whowouldathought...the Greddy TT community is single handedly wiping out the national inventory of 38cent diodes!
Suggestion here:
1) Instead of going to Radio Shack, try going to one of those geeky electronic parts stores like Marvac Electronics or something. Every city has one of these nerdy little stores...usually a hole in the wall...usually manned by social outcasts. They usually have an amazing inventory and diodes, transistors, and other generic electronic parts.
2) If they dont have the 50volt diodes (5100), and get the 100volt items (5101). See, any diodes will work since the voltage of those ignition ecu wires is 5volts max.
Old May 7, 2004 | 10:34 AM
etx's Avatar
etx
LOL! Yeah, it took me a few stops to find them as well.
Old May 7, 2004 | 09:29 PM
Sharif@Forged
Forged Performance
OK, I have really put the diodes and ignition harness to the test. I have driven about 300 miles in 100 degree weather through lots of stop and go traffic, and plenty of idling. Everything is still running fine. This was the best $40 i have ever spent!
Old May 8, 2004 | 09:39 PM
Enron Exec's Avatar
Enron Exec
Was there anything you guys had to do to unlock the emanage to retard the timing, or was it plug and play? Would it be a good idea to retard the timing a few more degrees in the #5 and #6 cylinders if they ran leaner?
Old May 8, 2004 | 10:30 PM
Sharif@Forged
Forged Performance
To make changes to the eManage, you have to inialize it with the profec e-01, then reenter the stock values. Then you can make whatever changes you want.
The eManage doesnt have the capability to retard timing in individual cylinders...it retards the same amount in all cyclinders.
Old May 9, 2004 | 07:39 AM
350Now's Avatar
350Now
Is it possible to make a new map similar by copying the stored map in the e-manage and change those setting? Kinda clone the pre-set Greddy setting then make the desired changes. That way you can always have your factory setting if you ever need to back to it.
Old May 9, 2004 | 07:41 AM
Sharif@Forged
Forged Performance
yeah, I stored the stock map in DATA1, and my 7psi map is now in Data2. The memory card in the Profec can hold up to three maps. Once I install the pump, I will put my 9psi map in DATA3.
Old May 9, 2004 | 09:08 AM
Enron Exec's Avatar
Enron Exec
So there is no way to use the Emanage to just retard timing w/o the Profec e-01?
Old May 9, 2004 | 09:19 AM
350Now's Avatar
350Now
You can use the Greddy Support Tool to program the e-manage fi you don't want the Profec E-01.
Old May 9, 2004 | 10:53 AM
Enron Exec's Avatar
Enron Exec
Oh ok, thanx 350Now.
Old May 9, 2004 | 06:30 PM
derek_i's Avatar
derek_i
Finally, I've found the 6th diode.
I should have it in this week...
-D
Old May 9, 2004 | 08:19 PM
Sharif@Forged
Forged Performance
True, but honestly the Profec-e01 is really whats brings the eManage to life. Otherwise, you need to carry your laptop with you and pull the carpet and kick panel to make changes. I also like that the Profec can display the data inputs and outputs on the screen....so you can REALLY know if the eManage is functioning properly.
350Z_Al
Oct 29, 2020 07:44 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tochigi_236
Sep 27, 2015 03:40 PM
