Greddy Overboosting
Old May 13, 2004 | 10:57 AM
Bini2's Avatar
Bini2
Default Greddy Overboosting
Forgive my ignorance, but why is my car overboosting?
I set the E01 boost controller into automatic mode with 5PSI and my E01 hits 6.4PSI at times.
So I set the E01 to manual mode with 20 and I overboost to 7 PSI....great.
What am I doing wrong? What causes the kit to overboost like this?
Thanks,
Clueless
Old May 13, 2004 | 11:11 AM
etx's Avatar
etx
For 5 psi just leave the e-01 off. You should hit 5.5 psi. I have seen the boot spike to 6 psi if i try to control the boost level with the throttle, that's not good. Just got WOT and you will get 5.4-5.5 psi.
Old May 13, 2004 | 11:16 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Using the manual mode is pretty scary, becuase you will boost different amounts based on gear, load, etc... I advise you not to use it.
In the auto mode. The 6.4 you are seeing is just a spike...watch your gauge and you'll see the spike, and then the Profec will take the boost down to the set level. You just need to play with the gain a bit to tighten it up. For instance, I have my boost set a 7psi, and 90% of the time, I hit that level right on, but on occasion, I'll get a momentary spike to 7.3psi, but then it drops right back down to 7psi.
The question is....the kit is boosting 5psi stock, so why are you even using the Profec boost control? If you want 5psi, just leave the boost off. Also, keep in mind, it is very challenging for any boost controller to just add 1psi to the stock wastegate...this leaves little margin for error. Boost controllers work best when taking the boost up 2 or more PSI over stock, so that solonoid has time to work correctly. Hope that helps!
Old May 13, 2004 | 11:22 AM
Bini2's Avatar
Bini2
Great, guys. Thank you both so much! Good advice.
Old May 13, 2004 | 11:41 AM
Chebosto's Avatar
Chebosto
"Just a spike" ??
dang.. from 5.5 to 6.4 isnt that assuring when you have fuel settings calculated for 5.5..
Old May 13, 2004 | 12:36 PM
350Now's Avatar
350Now
I also get's spike sometimes usually to 6.2psi. Good thing the fuel curve is very rich.
Old May 13, 2004 | 12:43 PM
Bini2's Avatar
Bini2
Yeah mine is tuned a little rich as well.
Old May 13, 2004 | 03:21 PM
Sharif@Forged
Forged Performance
Cheston, my spikes are only from 7psi to 7.3psi....and for just a split second.
When I have the controller off, the boost is ad 5psi, with an occasional spike to maybe 5.3psi or so.
Old May 13, 2004 | 04:45 PM
Bini2's Avatar
Bini2
Ok so 5PSI and a spike of 6.4PSI is not normal. Anyone have an idea about what is going on? Anyone else have this kind of inconsistancy?
Old May 13, 2004 | 08:00 PM
spazpilot's Avatar
spazpilot
make sure your gain is not set too high. that will create large difference in spike
Old May 13, 2004 | 08:48 PM
Sharif@Forged
Forged Performance
Bini....like I said...the controller cant set boost for 5psi when the wastegate is set at 5psi. boost controllers can only increase boost...not decrease. So the controller is still opening up slightly for some reason. Dont worry about it......its not designed to do what you are describing.
Just turn the boost to "off" and you'll be fine. Hope that helps buddy! If you are boosting 4.8psi without a controller, there is no controller on the planet that can stablize at 5.0psi....its just not that sensative.
Old May 14, 2004 | 06:56 AM
etx's Avatar
etx
^ True, You can't expect the unit to control the boost accurately to a tenth of psi. That's a very small measurement. One tenth of a psi is about a hundredth of a volt on the electronic pressure sensor, electronics tend to vary that much naturally anyways.
sales@czp
Sep 23, 2019 03:30 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
