JWT Oil Pan Spacer
Old Jun 6, 2004 | 02:25 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
Originally posted by NY 350Z
how much more oil can you put in?
already been answered in this post.. +1 quart.
m
Old Jun 6, 2004 | 03:38 PM
d_railed73's Avatar
d_railed73
Could you please make the picture larger and how much more oil can you put in it?
Old Jun 6, 2004 | 05:07 PM
tig488's Avatar
tig488
oh god, not you didnt
Old Jun 6, 2004 | 06:48 PM
Bini2's Avatar
Bini2
+1 Quart
Old Jun 6, 2004 | 08:01 PM
NY 350Z's Avatar
NY 350Z
cheap mod, im not to familiar with oil and capacitys, but will 1 more qt. really help alot?
Old Jun 7, 2004 | 10:32 AM
ChrisMCagle's Avatar
ChrisMCagle
Default A better idea
Ok, I think that JWT needs to design a better OIL DIP STICK!
God only knows how much oil you have when you try to read the stock stick.
-Chris
Old Jun 7, 2004 | 10:48 AM
G3po's Avatar
G3po
Default better dipstick
I second that
Old Jun 7, 2004 | 01:42 PM
NY 350Z's Avatar
NY 350Z
haha i THIRD that
Old Jun 7, 2004 | 05:47 PM
KyleB's Avatar
KyleB
ehhh... Won't the fill point be the same? You are adding capacity, so you will still fill it to the same point on the dipstick... I see no reason for a longer dipstick.
edit: nvm... misread the post. You are saying the stock dipstick is hard to read. MY BAD!
Old Jun 8, 2004 | 10:05 AM
ChrisMCagle
Yeah, the stock 350Z (and possibly the G35??) dipstick is a POS!! You insert it and pull it out and there is oil all the way up to the handle. The design is horrible. How about just a long thin piece of say solid .20 gauge wire?? None of the stupid bends and twists. The only way to accurrately tell how much oil you have is to drail it out and measure it.
Stock dipstick
Old Jun 8, 2004 | 10:13 AM
G3po's Avatar
G3po
Default dipstick
Well at least the extra qt of oil that the pan extender offers will CYA longer if your sucking more oil than expected.
Old Jun 8, 2004 | 11:53 AM
LOU's Avatar
LOU
I may have missed something here, but for those with a Vortech SC and this JWT oil pan spacer... do you have to tap the hole in a different location than what is suggested for a N/A or TT car?
Old Jun 8, 2004 | 01:26 PM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
We just got our first delivery of ten of these today. They are all sold.... except one... ... it goes on my car tomorrow. More are on the way if anyone wants one.
Old Jun 8, 2004 | 01:32 PM
whosdady's Avatar
whosdady
What is the cost to 350Z members on the spacer? Also how much are you charging for installation?
Old Jun 8, 2004 | 02:31 PM
G3po's Avatar
G3po
Default spacer and oil return
a)If your car is NA and you use this pan extension, there is "no oil tap", it just drops the pan lower and adds an extra qt. of capacity.
b) If you already have installed a Vortech , then again there is "no oil tap" in this adapter, since the oil return was accomplished by drilling and tapping the upper oil pan assembly.
c) If you want to use this pan extension in addition to a new Vortech install, it is possible to drill and tap this adapter , so that ypu can avoid drilling and tapping the upper pan assembly. However; some form of "J-pipe" will be needed inside the pan adapter to guarantee that the drain level is above the oil fill level.
d) If JWT can be compelled to sell the TT specific adapter independently , then it should already have two drain ports , one for each Turbo. So the passenger side tap would be plugged and the driver side could be used as a Vortech drain.
Hope this helps..
Old Jun 8, 2004 | 06:34 PM
LOU's Avatar
LOU
G3po, thanks a lot for the info! You answered my questions.
Old Jun 9, 2004 | 04:52 AM
Jeff@Performance
Performance Nissan
The spacers run $99.95, gaskets (silicone) $10.00 and labor $70.00
http://www.performancenissanparts.co...roducts_id=741
Old Jun 9, 2004 | 08:51 AM
  #38
ChrisMCagle
When I get my Vortech, I'll definitely be getting one of these too.
Old Jun 9, 2004 | 10:46 AM
  #39
whosdady's Avatar
whosdady
You guys at Performance are excellent. I didn't want to feel left out so I ordered one.
I was reading about Chebasto's car and the measurments taken with his upgraded oil pan and there was a huge difference. I would expect similar results with the spacer. I will post my review next week.
Old Jun 9, 2004 | 08:40 PM
  #40
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
We are including sealant with all oil pan purchases...
here is a pic of a unit i took today... Pictured is everything included in the kit (minus the instructions) and the actual sealant that gets sent to you...
We also havethe ARC Finned Oil Pans which hold the same extra Quart of oil...
Both can be purchased here...
http://www.performancenissanparts.co...th=153_174_379
I was just giving authorization to blow out our one nismo oil cooler for over 300 below cost!
PM me for that...
