Changing Fuel System to a return style
Originally posted by ACP
Mike, You have been reading my posts right ?
I am making a fpr plug
Our 1st order is just for a dozen. About 8 are called for so far...
Also, at the same time, I am getting fuel rail adaptors made.
This will allow you to connect directly to the back of the fuel rail, with flex hose.
So for those that want to come off the fuel hardline, to a flex hose, then FPR, then to the fuel rail, can easly do so, and don't have to get into removing the fuel rails.
I have been reading your post but didn't realize that you had extras. That is all I need to finish and have been looking at several different options. If there are any left out of the original order then please count me in? PM me for the price and info if you can. Thanks for your research and keep the good post/pictures coming.
Thanks,
MIKE
You guys don't need to run a return line for fuel pressure adjustments unless you intend to run less than 3.5 bar.
Here are some links I made on the subject 2 years ago.
http://forums.maxima.org/showthread....hreadid=123025
SR20DEN,
In your diagram, you show a return line back to the "high power fuel pump". The doesnt have a return at the tank or pump at all. it has a POS in-fuel-pump-assembly- fuel pressure regulator that dumps fuel at 50psi..but cant keep up with the Walbro 255.
On our stock returnless system....there is only one line coming out of the tank...at it heads to the fuel rail. There is nothing at all coming back to the tank.
Did I miss something?
PS I am moving to Charlotte in 4 weeks from LA...see ya soon!
Originally posted by gq_626
SR20DEN,
SR20DEN,
Although I no longer use a dry nitrous system so I don't have a need to boost the fp.
Originally posted by SR20DEN
Your setup is usually to change from a carb setup to modern fuel injection since Carb fuel pumps are usually low pressure type. With this setup you can supply the engine with high pressure.
Your setup also are commonly used in a sump setup to prevent fuel starvation during cornering, braking, and start up.
Plus, in your drawing, you forgot to add a surge tank so you can dump the excessive fuel back in it and feed it off again from the bottom with the high pressure fuel pump. Here is where your problem is. Even with a surge tank, what you do when the surge tank is completely full and no where to dump the fuel back to the tank? The fuel will pressurize the low pressure feed line again and again making the setup useless except you now have two fuel pump pumping fuel. Either way you need a return line to dump fuel back into the fuel tank or might as well ditch this setup and just start adding multiple fuel pump if that's what you are trying to do.
Use the same Aeromotive FPR. There is two side ports and one return port on the bottom. Total three ports.
Cut the fuel feed line in half somewhere before the rail. Stick the Aeromotive in between the cutted feed line using the two side ports so you are feeding fuel into one port and out of the other port into the rails. Use the bottom port for return back to the fuel tank.
This way you use less fittings, almost no stainless lines except for the fuel return and no welding are required.
You still have to get rid of the stock fpr in the back and change to walboro 255HP. My suggestion is only toward the engine bay fuel setup.
This may be a little hard to understand but the After market FPR that have two side ports are not dedicated as where it mounts before or after the Rail. Basically you can feed fuel through it and excess pressure can be return fuel from the bottom. You can return fuel into one or both side of the side ports and return from the bottom. You just cannot feed fuel into both port at the same time as there is no point in doing so anyway.
Here's some food for thoughts....
A fuel returnless system. I WOULD think the ecu can detect a rise in fuel pressure to throw a check light since this system need a very steady preprogrammed fuel pressure so it don't have to return any fuel back into the tank. Now you make it into a returnable fuel system. If the fuel pressure stays steady at factory spec, there may be no problem. But if you raised the fuel pressure and the ecu can in fact detects that, wouldn't there be a problem? By using a after market 1:1 fuel pressure regulator for boost, every pound the boost rise, the fpr will also raise the same amount of fuel pressure to compensate for the injector. So when you are running 20 pound of boost, you just added 20psi more on top of your base fuel pressure. That's 20psi of fuel pressure the ecu detects and throw you a code.
Like I said, i am not 100% sure if there is a fuel pressure sensor mounted somewhere alone the fuel line that ecu reads from so what I said above might not be a problem.
A good example would make my claim false is Vortech supercharger set up since it uses their FMU to rise fuel for enrichment which did not throw a light or given the ecu a hard time.
Oh btw.... I love fuel system setups. It's the most important aspects in your turbocharging. Get it right and you are a happy camper. Have a good time turbocharging!!
Originally posted by Evo Hybrid
There is couple problems with your drawing...
The main feed line is used for the purpose of feeding and scavenging. I have already said that I have proven this setup works just fine. It's quite simple, there is no need to make it look and sound more complicated than it really is.
The Nissan ECU does not read the fuel pressure.
Edited: All i'm trying to say is if you aren't scavanging the fuel back to the fuel tank, your setup is running crazy amount of fuel pressure to your injectors. It might work but not for long until the injector fails.
BTW: I was lazy and didnt' read through the entire thread.
GQ_626 has the same idea as what I wrote about sticking an fpr in between the fuel line before the rail.
ACP's way is to supply both rail with equal amount of fuel and make it returnable. More work but much safer for high boost.
Underterminable number? Did you not see the inline FPR? Everything is coltrolled and the FP is set to the desired amount. However that diagram is for a passive booster pump that would come on only when needed. An active setup for FI would replace the FPR with a FMU.
