vortech belt problem...help!
Hey guys, i am almost finished installin my kit, and i came across a problem. the main serpentine belt is rubbing against the upper and lower part of the engine that sticks through the plate. anyone else have this problem? if so what did you do?
Thanks for the help in advance!
I know looking at mine , the belt comes with in a 1/16 of an inch away from the bolts . Does your belt squeel at start up ?If so its to loose and will jump around and hit them bolts . Other than that I see 3 spacers , one is very small and the other2 [lower ones] I cant tell if they are the same size or not . If they are diff. size , one may be in the wrong spot , letting the bracket sit closer to the motor. Hope you figure it out
350Z_Al
Oct 29, 2020 07:44 PM
Vigman
Nov 17, 2015 04:34 AM
