Help Wideband Commander install G35c
Old Jul 16, 2004 | 08:27 PM
dfw350z's Avatar
dfw350z
Default Help Wideband Commander install G35c
I am installing a new Wideband commander unit to log/monitor A/F. I need to verify the following connections at the ECU harness. Anyone with knowledge please let me know if this seems correct. My tech manual says the following:
** Throttle Position Sensor **
Accelerator pedal fully released More than 0.36V
Accelerator pedal fully depressed Less than 4.75V
Terminal number 50 White wire
-OR-
Accelerator pedal fully released Less than 4.75V
Accelerator pedal fully depressed More than 0.36V
Terminal number: 69 R/L color
* Not sure of the correct connection to use
** RPM Sensor **
Pin Color
60 PU Ignition signal No. 5
61 WL Ignition signal No. 3
62 RY Ignition signal No. 1
Old Jul 18, 2004 | 02:35 PM
dfw350z's Avatar
dfw350z
Ok I got the TPS sensor worked out but I am not able to find a reliable RPM sensor connection. Does anyone know what wire to connect for RPM input ??
Old Jul 18, 2004 | 03:16 PM
esemes's Avatar
esemes
dang, i cant helpya here either.....
i know (for sure) my SM and tech will know this....
PM me if you are still stumped, and i'll PM you his contact info (he's also a member here,)
Old Jul 18, 2004 | 07:22 PM
dfw350z's Avatar
dfw350z
Thanks - I am calling my installer tomorrow, if he does not know I will PM ya...
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
