Lost power after exhaust & plenum install
Old Jul 18, 2004 | 05:52 PM
zachcrosen's Avatar
zachcrosen
Default Lost power after exhaust & plenum install
About a month ago, I made my 1st trip to the strip. I have a 5AT. At that time, I had a Popcharger, test pipes and a grounding kit. My best time was as follows:
R/T 1.282
60 2.322
330 6.256
1/8 9.469
MPH 77.33
1/4 14.542
MPH 96.67
Last night, I went out again. This time I had the Popcharger, grounding kit, Test Pipes Kinetix plenum and Injen true dual exhaust. My best times were worse this time. My best time is as follows:
R/T 1.068
60 2.308
330 6.389
1/8 9.686
MPH 74.26
1/4 14.848
MPH 95.75
I am also running on stock tires. Could someone give advice as to why I ran worse times. I ran 6 runs last night and I only had 1 R/T over 1.0 and this was with my best run. My 1st time to the strip, I had 4 runs and my R/T's were all over 1.00. I have roughly 15k miles on the car, if that matters. I realize that elevation, air temp, etc makes a difference, but damn my times suck a$$!! I also noticed a drop in my MPG. Prior to the install of my exhaust and plenum, I ran a constant 20.6 MPG. Now I am running low 19's. Oh yeah, I ran an AutoX today and the strip Friday, so that is some of the reason for my lower MPG, but not all of it. I have also noticed a considerable amount of blackish **** on the inside of my exhaust pipes. I am thinking I am running rich but I dont know anything about this A/F stuff. I am going to purchase an AEM Wideband probably tomorrow so I can find out what I am running. What are ideal ratios on a NA Z? I dont really want to get an ECU reflash done now due to the cost. I am thinking of going with the Apexi SAFC and have a local tuner install and tune it. Any questions/comments are greatly appreciated. Sorry for the LONG post!!!
Zach
Zach
Old Jul 18, 2004 | 06:53 PM
MIAPLAYA's Avatar
MIAPLAYA
R/Ts dont mean anything unless you are using a pro tree. On test and tunes reaction time can be as high as you want the time doesnt start until your wheels move
Old Jul 18, 2004 | 09:15 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
ZAch
You MUST do an ECU reset before drawing any conclusions.
THe procedure that always works for me is a full 24 hour battery disconnect, followed by several spirited WOT runs after the reconnect. From my experience, the ATs are a tad more temperamental this way than the MTs. THen again, this has not been confirmed in any objective way, just my experience.
G
Old Jul 19, 2004 | 04:12 AM
esemes's Avatar
esemes
ambient temp??
track temp??
tire press/temp??
fuel load??
these all are the actors i would need to have (to make comparison)
dont fret it (and listen to gurgen's advice too)
-eS
Old Jul 19, 2004 | 08:36 AM
zachcrosen's Avatar
zachcrosen
I am going to try resetting the ECU when I get home from work via disconnecting the battery. Hopoefully this will help.
Old Jul 19, 2004 | 10:23 AM
etx's Avatar
etx
You could try this as well. Less waiting.
http://www.technosquareinc.com/350reset.htm
MAsSIVrOOM
Oct 20, 2023 10:50 AM
hulkout
Apr 28, 2017 09:00 PM
allmycarsdie
May 13, 2016 04:38 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
