Vortech broken pulley pics.
Old Jul 28, 2004 | 07:08 PM
esemes's Avatar
esemes
i second the "hmmmmm" (or third it!)
the three bolts secure the blower. period. tow bolts will allow some oscillation under load, but the third bolt now triangulates the load (the triangle is the strongest geometrical shape) and will keep the blower sound.....
IMO, of course.....
anyway....
hmmmmmm..... backatcha!
S
Old Jul 29, 2004 | 08:45 AM
Forced's Avatar
Forced
Sorry all. I didn't mean for the "hmmm" to sound that I was saying that was the cause of the problem. It was more of a "Hmmm...I wouldn't have done it that way."
Old Jul 29, 2004 | 08:54 AM
mcduck's Avatar
mcduck
the 4th bolt is not related to this issue. I had the same problem occur on my Z and everything was mounted to spec. fortunately, mine did not incur the level of damage dollar's did.
Old Jul 29, 2004 | 09:11 AM
esemes's Avatar
esemes
are these pulleys billet, or what???
i wonder if its an issue with the composition of them........
maybe TI pulleys would be a good idea.....
Old Jul 29, 2004 | 11:17 AM
Forced's Avatar
Forced
They are 6061...
Old Jul 29, 2004 | 05:26 PM
bigern1970's Avatar
bigern1970
Originally posted by zimbo
Well I'll "Hmmmm" right back at any implication that somehow leaving out the 4th bolt was the cause of Jimmy's problem.
--Steve
so leaving the 4th bolt off has no bearing on pulley alignment, you may think its on snug, but who really knows if theres any misalignment during hard WOT runs?
Old Jul 30, 2004 | 07:23 PM
dollar99's Avatar
dollar99
I don't think my pulley issues has anything to do with the blower flexing or vibrating on WOT runs. The rubber belt should allow enough flex to counter this problem. I think my pulley problems is caused by compressor surge from the BOV being too tight. Cause the belt wants to spin the compressor one direction while the surge causes the compressor to want to spin the other direction.
Old Jul 30, 2004 | 07:28 PM
booger's Avatar
booger
Hey dollar...could you hear the surge ? When I was adjusting mine.....and went to tight...I could hear a loud flutter. Backed it off and it stopped
Old Jul 30, 2004 | 07:39 PM
dollar99's Avatar
dollar99
The fluttering sound is the worst compressor surge possible. Suppose you let off the gas and engine brake, the vortech bov should make a constant "shhhhhhhh" noise. If yours makes a fluttering sound then you have very bad compressor surge. If you only hear the fluttering noise when shifting, you're bov is still too tight even though it sounds awesome. If your bov makes a "ke pisshhh" sound when shifting, this is a very SLIGHT compressor surge. If your bov just makes a "pshhhhh" sound then there is no compressor surge.
Old Jul 30, 2004 | 07:45 PM
booger's Avatar
booger
No...Ke pisshh here...only psshhh
Old Jul 30, 2004 | 07:52 PM
dollar99's Avatar
dollar99
You should be fine. Mine made a "ke ke pishhh" sound.
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
