A/F Question
Old Aug 7, 2004 | 07:17 PM
zachcrosen's Avatar
zachcrosen
Default A/F Question
I got my AEM Wideband installed today and had a few questions. First, I dont know very much about A/F ratios. At idle, my gauge is reading 14.6-15.1. At cruising RPMs, whether it be 25 or 90, the gauge is between 14.3 and about 15.3. When I stomp on it hard, it drops down in the 11s and 12s. Could someone who is very knowledgeable about AFR tell me exactly what these mean and if these readings are bad/good? Thanks in advance.
Zach
Old Aug 8, 2004 | 07:40 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Your reading are normal. At cruise, minor part throttle, or idle, your AF should be near 14.7:1...slightly higher or slighty lower is fine, becuase it tends to bounce around a bit. Under these conditions, the ECU is reading your 02 sensor readings and trying to maintain stoich conditions.
When you go WOT, the ECU disregards the 02 readings, and adds fuel based on MAF sensor inputs. So when you floor it, the ECU see more air, and adds way more fuel. If you are in the 11- 12's under WOT for an N/A car..that is a bit rich...but not too bad.
Ideally in an N/A car, people are shooting for high 12's to 13:1, and F/I cars are shooting for 11.5:1 for safety.
All and all...you look OK!
Old Aug 8, 2004 | 07:59 AM
zachcrosen's Avatar
zachcrosen
Thanks for the feedback!!!
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
