Need "Profec e01 for Dummies" Course
Old Aug 24, 2004 | 06:21 PM
350G's Avatar
350G
Default Need "Profec e01 for Dummies" Course
Well, its getting closer to my install date and I'm trying to finalize the gauges. I know the profec e01 will display my boost, but what other things can it display (with / without optional accessories)? I appreciate it in advance . . .
G
Old Aug 24, 2004 | 08:09 PM
zimbo's Avatar
zimbo
It can display RPMs (using the special RPM adapter that tees into each of the 6 ignition lines from the ECU), it can display data from an external source such as a Wideband O2 sensor--assuming you purchase the external signal harness).
I haven't figured out how to play Pong on it yet...
--Steve
Old Aug 25, 2004 | 07:33 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It can display every input and out coming from the eManage. The USB cable is what transmits everything back and forth between the emanage and profec.
Optional items are the external signal harness that zimbo mentioned above. Lets you display numerous externals signals to the profec..such as a wideband O2, or fuel pressure. The other optional item is the boost pressure sensor harness. For some reason, you need this to rely the boost signal from the profec to the eManage. Not sure why they just didnt incorporate that feed into the USB cable along with everything else.
Old Aug 25, 2004 | 07:39 AM
350G's Avatar
350G
So basically, I can get the harnesses and display these readings . . . so do I really need any gauges?
I've got the ignition harness with adapter. Does anything get displayed?
Thanks for all the help!
G
Old Aug 25, 2004 | 11:11 AM
Bini2's Avatar
Bini2
The manual is very easy to understand and goes over allot of the concepts.
In case you have not read it: http://www.350tt.com/tt_kits/greddy/e01_manual.pdf
Old Aug 25, 2004 | 06:44 PM
350G's Avatar
350G
Thanks!!! I haven't been able to preview the manual since its in the box with all the parts (not at home).
G
Old Aug 25, 2004 | 10:52 PM
03_ppw350z's Avatar
03_ppw350z
wow how do i gete fuel pressure on there? didnt know i can do that
Old Aug 25, 2004 | 10:56 PM
350Now's Avatar
350Now
For fuel pressure you need to get a fuel pressure gauge or a sensor and know the voltage reading. Once you have that you can tap that into the optional signal harness, and use a conversion so the E-01 know how to translate voltage to some value.
Old Aug 25, 2004 | 10:58 PM
03_ppw350z's Avatar
03_ppw350z
oh gotta buy a sender
got ya
Old Aug 25, 2004 | 10:59 PM
350Now's Avatar
350Now
yup.. i'm using the DEFI D-Gauge fuel pressure gauge, and I've tap the sender line so I can data-log fuel pressure in the E-01.
Old Aug 26, 2004 | 03:06 AM
westpak's Avatar
westpak
SFZCC
One thing is that you can only display 3 items at a time on the eO1, so depending on what you want you have to pick the 3 you most want or add gages. I am picking Boost, AF as a must and RPM's as the third.
Old Aug 26, 2004 | 05:49 AM
Sharif@Forged
Forged Performance
even though it only displays three inputs, dont forget that it datalogs all of them.
Old Apr 27, 2007 | 06:33 PM
IslandZavage's Avatar
IslandZavage
i read the manual and it refers to e-manage alot. Does any of this change/apply for UTEC users?
Old Apr 27, 2007 | 07:13 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
nope, the EO1 will work perfect with your setup. nothing is different with it with the utec...
see ya soon!!
Old Apr 28, 2007 | 08:01 PM
mario23's Avatar
mario23
bcoffee20
Nov 19, 2015 06:39 PM
westpak
Sep 2, 2005 12:14 PM
MIAPLAYA
Dec 23, 2004 05:09 PM
redline tt
Nov 27, 2004 10:41 PM
MardiGrasMax
Oct 31, 2004 06:33 AM
