help, wierd noises.
Old Aug 29, 2004 | 10:54 AM
2003z's Avatar
2003z
Default help, wierd noises.
background: This started after going to the drag strip firday night, and I was running ET Streets. The drive home had no abnormal sounds.
Now, the car has a wierd knocking sound under load, usually in gear, but I think I can faintly hear it in neutral. Hard to hear over the supercharger when not loaded. Its hard to describe, but if you put a bunch of bolts in a wooden box and tumbled it, it would be a similar sound. My thoughts are Internals (no MIL codes, good oil psi, good wideband readings), clutch (doesn't slip at all), or flywheel, but I have no other ideas. I guess it could also be brakes rubbing somewhere, because it makes noises when I stop, albeit different noises. I'm getting ready to put the car on jackstands and check everything for tightness, but has anyone else experienced anything like this? Its not real loud.
Old Aug 29, 2004 | 12:09 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Is it pinging? Detonation? Joenismo's car made some knocking noises coming from the engine...before the rod snapped. So get that checked out right away.
Old Aug 29, 2004 | 12:15 PM
2003z's Avatar
2003z
no, its definitely not coming from the engine. Its underneath. Poking around, it seems as though the driveshaft might have excessive rotational play. Have you ever tried to rotate the driveshaft by hand and discovered any play at all? I don't remember it from before, but I never really paid much attention to it. When I jiggle it and it makes contact in the transmission, it makes a noise like I am hearing.
Old Aug 29, 2004 | 02:05 PM
Duflacci's Avatar
Duflacci
maybe in the clutch assy?
Old Aug 29, 2004 | 04:13 PM
zachcrosen's Avatar
zachcrosen
2003z, were you at commerce Friday night? I had some friends that were there?
Old Aug 29, 2004 | 04:20 PM
etx's Avatar
etx
Were you on stock tires? Slicks or drag radials could put excessive load on the rear end and the clutch plate. That's my only guess. I've run M&H drag radials at the track and pulled off some good 60's (1.79) and I haven't had any problems. Mabye your CV joints got messed up, it's hard to say.
Old Aug 29, 2004 | 04:59 PM
2003z's Avatar
2003z
Yeah, I was at commerce, and I was on ET Streets. After further inspection and test driving, I found a couple loose aero panels underneath, which may have been part of the noises, and also realized its nothing to do with the engine, because it makes noises over bumps, in or out of gear. I think its just normal squeaks and rattles, I've just don't normally hear them with the radio on. I'm just paranoid I guess. The sound is louder with the windows closed, and going over the curb into our driveway, my wife couldn't hear it from outside the car, but I could hear it inside.
wanderingstuden
Jan 28, 2016 07:03 PM
cashmoney03
Sep 27, 2015 05:24 PM
zachcrosen
Sep 6, 2004 01:12 PM
ares
Jul 26, 2004 06:44 PM
peptidbond
Aug 24, 2003 04:41 PM
