Koyo Radiator install with GReddy TT IC
Old Sep 1, 2004 | 12:02 AM
ThoughtZ's Avatar
ThoughtZ
Default Koyo Radiator install with GReddy TT IC
Hey there I'm just looking for some tips on this install with the tt ic in the way. Havne't got under the car yet but plan to tommorrow. I've heard I may have to take the intercooler of to get to two screws. Anyone had to do this yet or know what needs to be done? Much appreciation in advance.
Old Sep 2, 2004 | 08:16 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
good luck on the install in the first place...despite what others have posted who sell it, it is NOT a direct bolt in. Not hard, but not direct install either.
adam
Old Sep 2, 2004 | 08:32 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
thats good to know...I was told by many that it bolts on, after removal and replacement of a couple of items.
Adam..can you elaborate on what is necessary to install it if you have the Greddy IC.
Old Sep 2, 2004 | 09:43 AM
spazpilot's Avatar
spazpilot
you have to shave a little on the electric fan assembly and a little on the front core support that holds the radiator and ac condenser. here is a pic of it installed though. It does fit if you have questions on were to shave drop me a line CJ.
Old Sep 2, 2004 | 09:44 AM
spazpilot's Avatar
spazpilot
pic 2
Old Sep 2, 2004 | 09:50 AM
spazpilot's Avatar
spazpilot
ok now if you really close were the intercooler comes close to the elctric fan. one of the support braces has to only has to be shave down. hard to explain but you will see what I am talking about. were it is circled.
Old Sep 2, 2004 | 10:09 AM
spazpilot's Avatar
spazpilot
I could not get a pic were you have to shave on the core support. sorry its hidden
Old Sep 2, 2004 | 11:30 AM
ThoughtZ's Avatar
ThoughtZ
Alright so the problem im running into is basically dropping the radiator back into place it gets snagged on the right side and doesnt go totally down so this is where the shaving comes into place? The ac condensor is nothing but a pain in the *** at this point but what problems did you run into with this. Crappy part about this install is you really are stuck until its done lol there's no half way mark where you can pick up later.
Old Sep 2, 2004 | 02:56 PM
Z1 Performance
Former Sponsor
Exactly right ThoughtZ...my guys were CURSING me the day we put this in.
What we ended up doing was trimming what I can describe as the lower rad support, and then it went in with a bit of elbow grease.
With a GReddy FMIC...hmmm...I have to sit down and give that some thought as its been a while since we installed one
Old Sep 2, 2004 | 04:54 PM
ThoughtZ's Avatar
ThoughtZ
Well the fmic is not even remotely an issue it was just the clearance to fit the new radiator with the fan attached and the air condensor back in there. Since with the TT kit we have those extra air filters. It's a lot of tweaking and pushing/pulling to get it out to begin with but the wider Koyo one makes it quite the affair. We're going to hack at it again tommorrow so I'll keep this updated with pictures of what we did so that later one people won't stress out like we have lol.
Old Sep 14, 2004 | 08:18 AM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
The only modification we have seen when installing the Koyo radiator is to modify where the AC condensor sits in the Radiator Tabs. You have to dremel the plastic shroud a little bit. It is not noticable but just the area inside where the tabs fit. If anyone has any questions on this please don't hesitate to call me. It is snug on the sides but we were able to fit it in without a problem. It took us approximately 20 minutes from start to finish, but that was without the TT kit installed though.
Greg
(859) 224-0461 ext. 222
Injected Performance, LLC
Old Sep 14, 2004 | 04:27 PM
350Now's Avatar
350Now
I have the Koyo as well but didn't do the install myself. I will check to see what was needed to be trimmed to get it to fit. I always thought it was a direct replacement.
SharX59
Sep 30, 2015 10:54 AM
