Guys... I got a problem... Car Smoking...
Old Sep 3, 2004 | 09:30 AM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Originally posted by mr2fasterthanyo
I agree with pretty much everyone else.
Anytime i have seen oil leaks like that, it is either the turbo seals, PCV, or oil return lines.
on MR2's, if you keep the PCV valve plugged into the intake you can get a fair amount of oil build up. I always just plugged it and put a catch can and breather filter on the PCV hose. (i had removed all the emissions equipment anyways, no need for that)
Your compression still looks good, so i dont think it would be the rings or any internal part of your engine. I would put my money on a plugged oil return line on the turbos or bad seals. I have used Greddy turbos before (TD06's) and have gotten 1 or 2 that the internal seals were fried upon installation and had to send them back to be rebuilt.
good luck
MR2,
So is it ok to not keep the crankcase in relatiovely negative pressure, like it was designed? I guess I can easily tell by taking off the intake filter and see if there is a lot of oil in the tubes...
So how do you "check" the PCV valve?
The FSM shows a procedure for this, you are supposed to take off the hose off the top of the PCV valve on the p-side rocker cover and while the car is running , check with your finger to see if there is suction on top of the valve... i.e. air being sucked into the crank case.
Occom's Razor suggests that it is NOT the PCV valve, but something that PE USA took off and put on.
I am pissed and disappointed...
Gurgen
Old Sep 3, 2004 | 10:36 AM
THX723's Avatar
THX723
Originally posted by gurgenpb01
Clint,
That would explain it for sure... he did take off the feeder and the return line. So, SHould I just take them both off?? I do also think that it is more likely to be a return line issue... rather than a bad seal... Given the circumstances of how/when it happened.
I talked with PE USA, they are about to get back to me after speaking to Mokoto. There is just no way in hell that it is a coincidence!
Gurgen
Sometime if the fitting is screwed in too far flow is greatly restricted or cut-off completely in worse case scenario. You could try unscrewing the lines from the fitting first, then back out the fitting 1 full turn. Start the car ... let it warm up, then do the free rev test and see if the same smoke is still there. You may see some leaks around the fitting in the mean time, but that could be addressed later by reinstalling it w. new teflon tapes applied. Don't forget to perform this for both return line.
Good Luck.
Old Sep 3, 2004 | 02:24 PM
zimbo's Avatar
zimbo
Occom's Razor suggests that it is NOT the PCV valve, but something that PE USA took off and put on. I am pissed and disappointed...
I can empathize with your frustration. It's like you said to me on the phone the other day. Us sedan guys are just glorified Beta testers
In the meantime, Occam's is my favorite brand of razor.
--Steve
Old Sep 3, 2004 | 02:31 PM
g356gear's Avatar
g356gear
--Steve
Amen to that Zimbo
Old Sep 3, 2004 | 08:58 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
--Steve
Well... I am not sure about glorified..... just kidding.
Well, frankly I meant that regardless of what we do, the car is still going to be beta, forever.... and we need to accept that. We can, however, get really really close to a production level reliability (assuming it's a high quality production car) with a built motor... Then the drivetrain becomes the weak link.... it never ends. Lets just get a Porshe and be done with it... (j/k again)
As far as the car is concerned... I am going to drive it for now and see if it changes.... I checked the charge pipe on the p-side along with removing the plenum to look for oil. In both cases, especially the latter, it was clean (the charge pipe looked pretty much identical to the preTB tube picture I posted above). I also took a quick look at the retun line for kinks... it was straight....
Will get into it more next week... will be taking off the X- pipe and starting the car to see if the smoke comes from one or both turbos... that should give us a clue... Removing test pipes is also an idea....
Gurgen
Old Sep 4, 2004 | 09:55 AM
350Now's Avatar
350Now
Hey Gurgen, sorry to hear about the smoke hopefully you can isolate the issues. What's been posted above are great possibilities.
Old Sep 5, 2004 | 01:27 AM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Hey Guys
Thanks for all your help and advice, they were all truly helpful.... What is weird now is that I sometimes (for example during today's dyno day) observe no smoke after a boosted run... However, smoke is ALWAYS present after I rev the car while in Neutral/Park position, just free-rev I mean.
Mokoto (PE Engineer), said that you never should free-rev these VQ engines b/c of some great vacuum tha is created that can suck the oil through (not sure exactly what he meant as much of it was lost in translation from Japanese).
For now... I will try to replace the test pipes, or at least take them off to inspect the turbo exhaust outlet (pre-down-pipe) for oil/carbon residue...
Will report back with any news...
Gurgen
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
