Greddy TT . . . cylinder #4 gone
Old Sep 8, 2004 | 03:51 PM
ChrisMCagle's Avatar
ChrisMCagle
Did you visually inspect the pins in the ECU connector? It's possible that the pin got bent and therefore is not sending or recieving a signal from the wire harness? Stranger things have happened. It's worth looking into rather than buying a new ECU. Also, when they wired everything up, did they cut the ECU wires to splice the eManage harness in, or did they just remove the wire cover a little and then wrap and solder? It's possible that there is just a bad connection in the wire going to the ECU?
my $0.02
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
sales@czp
Sep 23, 2019 03:30 PM
