2 Step ??
Old Sep 19, 2004 | 01:56 PM
03_ppw350z's Avatar
03_ppw350z
Default 2 Step ??
does anyone make a 2 step that would work for the 350z? im looking for one i know somone has to have one that will work.
Old Sep 19, 2004 | 03:31 PM
Enron Exec's Avatar
Enron Exec
Whats a 2 step? And how is your engine build comming along? Do share!
Old Sep 19, 2004 | 05:33 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
Yes please elaborate
Old Sep 19, 2004 | 09:20 PM
dynamic6er's Avatar
dynamic6er
The MSD DIS-4 should work. You may need the dual channel ignition adaptor so the ecu can read the modified signal.
2-step is an ignition control module that allows you to set a specific rpm to hold the engine at (say 3500 RPM) with the accelerator floored during a launch. It will cut individual cylinder ignition out so that you don't exceed your set launch limit. Always fun to play with people never expect it on the street
Old Sep 20, 2004 | 01:51 AM
03_ppw350z's Avatar
03_ppw350z
my engine build was done a month ago i have been posting the progress in the drag race section so far i still have the 440cc injectors so im stil limited on boost but i have run 11.4@127 already with 13.6 psi i tried bumping the boost up more with some gas but it didnt work to well i jus have to buy new injectors and i will get it tuned as it still haas the stock greddy map
Old Sep 20, 2004 | 01:54 AM
03_ppw350z's Avatar
03_ppw350z
here my race setup 15x3.5 prostars in the front and weld xp prostars 15x8 rear with 26x10.5-15 et streets best 60ft was a 1.78 so far my car still spins these tires even at 12psi of tire pressure. i want a 2 step so i can build boost on the line and leave off boost when i drag race. it helps your times!
Old Sep 20, 2004 | 04:45 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Due...you really need to post up some details of your engine build in a dedicated thread....pleeeeeeeeeease. and some pics.
Old Sep 20, 2004 | 04:48 AM
Chi-TownWarrior
Sweet setup.
One system that has been very popular is the setup by racelogic. Its good system, and I have read lots of reviews on it. As soon as I get the money I might put it on mine.
Racelogic
Old Sep 20, 2004 | 07:51 PM
Enron Exec's Avatar
Enron Exec
Wow! Those are some terrific times and one hall of a trap speed! I bet if you get your launch down and 60' down, you are in the high 10's!!!!
I ran that trap speed through a calculator and it says u are ruffly putting down 553 rwhp!
Are you still on the stock 6MT? Stock rear diff? Please do tell.
Old Sep 20, 2004 | 07:53 PM
Enron Exec's Avatar
Enron Exec
Oh yea... stock sleeves? Fuel system? PLEASE !
35reilly
Sep 28, 2015 07:42 AM
samansharif
Sep 25, 2015 12:31 PM
