What breaks rods: Boost or HP/Torque
Old Sep 23, 2004 | 04:12 AM
zimbo's Avatar
zimbo
Well, clearly if there are companies who believed they have found a fix to a pre-detonation cylinder pressure problem then it is very likely something ECU or sensor related rather than something mechanical.
Knock sensor, cam sensor(s), crank position sensor, etc.
I'm also wondering if this is something that happens more in, say, 03s than in 04s. That would also lend itself to being an ECU-related issue.
--Steve
Old Sep 23, 2004 | 08:19 AM
350G's Avatar
350G
I guess time will only tell . . .
*Jeopardy music*
Old Sep 23, 2004 | 09:00 AM
G3po's Avatar
G3po
Default bent rods
*Jeopardy music*
Given the block I've inspected there appeared to be no top cylinder damage which would indicate prolonged detonation. A rod shouldn't bend via "detonation" alone and not show some amount of top side damage. Now it is possible that the condition being uncovered is "pre-ignition". Note this is a different phenomena than detonation. Even though detonation may be a pre-cursor to pre-ignition , pre-ignition can exist with detonation. Preignition could esaily bend a rod in a very short interval (even a forged one).
Old Sep 23, 2004 | 09:14 AM
IceY2K1Max's Avatar
IceY2K1Max
I agree....pre-ignition will kill a motor pretty much instantly vs. detonation that can be tolerated for long periods of time and slight detonation is even desirable for max fuel economy/emissions.
Someone better start spilling those beans....
Old Sep 23, 2004 | 09:22 AM
350G's Avatar
350G
Unfortunately, there's no beans to spill. The company is very tight lipped and I am waiting just as you are . . . Could someone regurgitate some of the common reasons for pre-ignition? (Discussion purposes only)
Old Sep 23, 2004 | 09:26 AM
IceY2K1Max's Avatar
IceY2K1Max
Try reading this:
http://www.streetrodstuff.com/Articl...ne/Detonation/
My guesses in SUSPECT order are:
1)Spark plug(run colder copper instead).
2)Ignition firing at wrong time(crank sensor problem?).
3)Hot spot in CC.
Old Sep 23, 2004 | 09:42 AM
G3po's Avatar
G3po
Default pre-ignition
Originally posted by IceY2K1Max
Try reading this:
3)Hot spot in CC.
Not that any other used the J&S safeguard and had failures. Gurgen did. J&S uses a wasted spark to expand the timing conrtroller to 6 cylinders. I have never been a fan of this method. If anything it frys your plugs twice a quickely , but it could also increase the probability for a pre-ignition event. The safeguard can protect against pre-ignition , unless detnation exists as a pre-cursor. Ideally "gate" the signals to support 6 cylinders rather an Diode OR them (aka wasted spark).
Old Sep 23, 2004 | 09:44 AM
G3po's Avatar
G3po
Default Re: pre-ignition
Correction :The safeguard can "NOT" protect against pre-ignition , unless detonation exists as a pre-cursor.
Old Sep 23, 2004 | 09:48 AM
IceY2K1Max's Avatar
IceY2K1Max
I was considering that also, however few have J&S. I was also considering the eManage ignition "burnt coil" issue, however I don't think everybody has been using that harness/firmware either.
I'm suspect of things that are common to all like plugs, crank sensor recall(at least on VQ35 Maximas), and these new heads.
Old Sep 23, 2004 | 09:52 AM
G3po's Avatar
G3po
"crank sensor recall(at least on VQ35 Maximas"
now that is very intriguing. ..
Old Sep 23, 2004 | 09:57 AM
IceY2K1Max's Avatar
IceY2K1Max
Looks like it applies to 2003 350Zs also:
http://maxima.theowensfamily.com/tsb/NTB03-124.pdf
Old Sep 23, 2004 | 10:03 AM
G3po's Avatar
G3po
Default pre-igntion
Dude , I think you really may be onto something.
Just as a CYI, "anyone" in the long block rebuild process should consider a new crank pos sensor.
Old Sep 23, 2004 | 10:16 AM
etx's Avatar
etx
Boost makes torque. Horsepower is a measurement of torque. Motors make torque, not HP. More Boost, more Torque, more Horsepower, More broken rods.
Old Sep 23, 2004 | 10:23 AM
G3po's Avatar
G3po
Default rods
Sure, but in my block's case (from Fernadito7) only a few miles at 7psi on a GreddyTT, two rods were bent. No top cylinder signs of detonation, and the crank power levels for such a short interval would unlikely to be the root cause. Now a pre-ignition scenario could explain at least "this blocks" root cause. I am at least going to attmept to test the sensors duing my re-build.
Old Sep 23, 2004 | 10:33 AM
ihatethatbobbarker's Avatar
ihatethatbobbarker
god im thinking so hesitently about forced induction now.
any PE Z's blown their motors or just gurgen.
perhaps single turbo is the way.
Old Sep 23, 2004 | 01:26 PM
350G's Avatar
350G
Default Re: pre-igntion
Could you elaborate on the sensor. . . I'm still learning this stuff.
G
Old Sep 23, 2004 | 01:41 PM
KyleB's Avatar
KyleB
Detonation
Detonation is the spontaneous combustion of the end-gas (remaining fuel/air mixture) in the chamber. It always occurs after normal combustion is initiated by the spark plug. The initial combustion at the spark plug is followed by a normal combustion burn. For some reason, likely heat and pressure, the end gas in the chamber spontaneously combusts. The key point here is that detonation occurs after you have initiated the normal combustion with the spark plug.
Pre-ignition
Pre-ignition is defined as the ignition of the mixture prior to the spark plug firing. Anytime something causes the mixture in the chamber to ignite prior to the spark plug event it is classified as pre-ignition. The two are completely different and abnormal phenomenon.
Old Sep 23, 2004 | 01:50 PM
  #38
G3po's Avatar
G3po
Default Re: Re: pre-igntion
G
It's a stretch , but there is a TSB on some 2003 VINs to replace the 2xcam sensors and the 1x crank sensor. Apparently they could either act intermittently or fail altogther.
A full failure would render the engine in-operable or even cause a safety issues. It woudl be obvious.
An intermittent could cause many bizarre symptoms. The crank sensor basically indexes "Time zero" for all timing operations in the engine . The ECU uses this input (along with CAM phase sensors to generate all spark timing and injector pulse positions. FOR eaxample the Tach signal is derived from this input. If this signal(s) acted "weird" it is quite possible that.. A boosted engine could turn this burp into a boom. Its all conjecture , just fishing...
Old Sep 23, 2004 | 01:52 PM
  #39
IceY2K1Max's Avatar
IceY2K1Max
NICELY said....exactly what I'm thinking.
Old Sep 23, 2004 | 02:21 PM
  #40
zzzya's Avatar
zzzya
I do not recall the G35s being a part of that recall, anyone know? If that is the case then Gurgen's car may defunct that theory. I am still worried about the heat generated under the hood. It would be interesting if anyone had engine temp and oil temp readings when engine failure took place as heat could stimulate detonation or pre-ignition. Where does everyone live who has bent their rods? Hot climates? Which fuel? Larger oil pans? Better radiators? What about intercooler design? Maybe this is a stretch but this engine/ecu seems to react to heat more than any other car I have owned.
