What breaks rods: Boost or HP/Torque
Old Sep 23, 2004 | 02:38 PM
  #41
G3po's Avatar
G3po
Default crank sensor TSB
Originally posted by zzzya
I do not recall the G35s being a part of that recall, anyone know? If that is the case then Gurgen's car may defunct that theory. I am still worried about the heat generated under the hood. It would be interesting if anyone had engine temp and oil temp readings when engine failure took place as heat could stimulate detonation or pre-ignition. Where does everyone live who has bent their rods? Hot climates? Which fuel? Larger oil pans? Better radiators? What about intercooler design? Maybe this is a stretch but this engine/ecu seems to react to heat more than any other car I have owned.
Yes there is a TSB for specific G35 VINs as well.
See the G35driver site.
As for underhood heat. It coudl contribute to dentonation issues.
But some thos the failures seen occurred very abrubtly. Detonation failure takes a a while to pound it's damage. Many of the early SC intalls were clearly tuner issues and engines were destroyed due to prolonged detonation. Ther is a whole other clasa of failures with the TTs that do not exhibit the exact same symptoms.
Old Sep 23, 2004 | 02:43 PM
  #42
IceY2K1Max's Avatar
IceY2K1Max
Engine Sensors Replacement Voluntary Safety Recall Campaign [Oct. 30, 03]
Background
Nissan/Infiniti will be conducting a voluntary safety recall campaign for engine sensors on certain model year vehicles.
Reason for Action
Vehicles are being recalled for replacement of the engine crank position and cam position sensors. Improper operation of the sensors could cause the engine malfunction indicator lamp (MIL) to illuminate; create a no-start condition or reduced engine power; or cause the engine to stop running without warning during vehicle operation. To this date, no accidents or injuries have occurred.
Nissan Action
To correct this condition, at no charge to the customer, the engine crank position and cam position sensors will be replaced.
Nissan/Infiniti plan to begin notifying owners of potentially affected vehicles in December requesting them to bring their vehicle to a Nissan/Infiniti dealer. In addition to direct customer contact (via mail), Nissan will post recall information on the www.nissanusa.com Web site at the same time owner letters are mailed.
Statement
"Nissan North America is conducting a voluntary safety recall of approximately 790,000 Nissan and Infiniti vehicles to replace the engine crank position and cam position sensors. On certain vehicles manufactured from January 2000 through July 2002, the sensors may not operate properly and could cause the engine malfunction lamp to illuminate; create a no-start condition or reduced engine power; or cause the engine to stop running without warning during vehicle operation. To this date, no accidents or injuries have occurred. To correct this condition, the engine crank position and cam position sensors will be replaced at no charge to the customer. Nissan and Infiniti are committed to a high level of customer safety and service and will be working with its dealers to promptly address this condition. Customers will be notified by mail if their vehicle is affected by this recall."
http://tennessean.com/business/archi...nt_ID=41658645
The company also recalled the following vehicles sold in the United States under its Infiniti brand: 2001-03 I35's, 2003 G35 sedans and coupes,
Old Sep 23, 2004 | 02:58 PM
  #43
KyleB's Avatar
KyleB
Default Re: crank sensor TSB
Detonation can cause very abrubt problems on a high output motor. Unfortunately a lot of detonation info is in in3 so we will just say that the 3.5l is approx 213.5 cu in.
The higher the specific output (HP/in3) of the engine, the greater the sensitivity to detonation. An engine that is making 0.5 HP/in3 or less can sustain moderate levels of detonation without any damage; but an engine that is making 1.5 HP/in3, if it detonates, it will probably be damaged fairly quickly, here I mean within minutes.
Detonation causes three types of failure:
1. Mechanical damage (broken ring lands)
2. Abrasion (pitting of the piston crown)
3. Overheating (scuffed piston skirts due to excess heat input or high coolant temperatures)
Taking this information into account, a stock Z motor has a specific output of about 1.3 at the crank. If you consider a 400hp twin-turbo, it has a specific output of nearly 1.9 AT THE WHEELS! Detonation at these levels can easily damage an engine relatively quickly.
Old Sep 23, 2004 | 03:23 PM
  #44
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I just started reading this thread. Very interesting. My car is a 2004, but I belive that all of the failures were on 2003 model 350Z's. ZRAYGO, JoeNismo, Fernandino, Bini2, Gurgen....just to name a few.
Wonder if we are on to something here.
Old Sep 23, 2004 | 04:52 PM
  #45
zimbo's Avatar
zimbo
Yeah, I wonder if ravaz's new motor is from an 03.5 or an 04, perhaps...
--Steve
Old Sep 23, 2004 | 04:56 PM
  #46
G3po's Avatar
G3po
Default Re: Re: crank sensor TSB
WRT
The damged longblock I have , has two bent rods and "none" of the symptoms mentioned. Hence why "pre-igntion" is being considered the cuplrit. Root cause is still a mystery..
Old Sep 23, 2004 | 06:16 PM
  #47
zzzya's Avatar
zzzya
Isn't it possible that since the rods are the weakest link, they could give away before ring or piston damage might occur given pre-ignition or detonation? Once the rod breaks, piston or ring damage might not occur since the rod is no longer in tact. Its unfortunate that rods are what is giving way since they tend to flop around and end up through the block.
Old Sep 23, 2004 | 10:24 PM
  #48
phunk's Avatar
phunk
CJ Motorsports
whats with this recall, i just read the thread. my vin ends with 010278... which means this car is a pretty early Z doesnt it? Is it the 10,278th? I never really paid much attention to VINs.
I still gotta take care of the axle clicking... dealer has my new taillight since one of mine gets water in it... now i guess i might need to tell them to order me up some sensors to change out too...
Old Sep 23, 2004 | 10:48 PM
  #49
APS's Avatar
APS
Default Re: Re: Re: crank sensor TSB
WRT
No doubt if this engine in question has bent con rods then the mechanical limit of those particular con rods has been exceeded for sure.
Maybe there's a performance variation in the mechanical properties of this high volume con rod.
I agree with you prognosis on engine detonation..............there's another common type of failure caused via continual detonation which big end bearing failure..............mainly seen in the top bearing shell.
Peter
APS
Old Sep 23, 2004 | 11:02 PM
  #50
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Originally posted by ihatethatbobbarker
god im thinking so hesitently about forced induction now.
any PE Z's blown their motors or just gurgen.
perhaps single turbo is the way.
I think it's just me. There are a quite few out there...
Old Sep 23, 2004 | 11:09 PM
  #51
GurgenPB's Avatar
GurgenPB
UltimateSleeper
We REALLY need to start a sticky thread with all the engine failures complete with all production dates.
Gurgen
Old Sep 24, 2004 | 04:01 PM
  #52
redline350ZZ's Avatar
redline350ZZ
Man im glad that ive stuck to N/A mod's so far... no offense to all but I hate being a test subject...... I hope the problem gets fixed guys........ cause then i'll go Single turbo.....
Old Sep 24, 2004 | 09:16 PM
  #53
Sharif@Forged
Forged Performance
yup...might be best to wait until the smoke literally clears before jumping into the F/I boat. Guess its too late for me now!
Old Sep 24, 2004 | 11:51 PM
  #54
GurgenPB's Avatar
GurgenPB
UltimateSleeper
And it's REALLY too late for me....... LOL
Old Sep 25, 2004 | 08:01 AM
  #55
ihatethatbobbarker's Avatar
ihatethatbobbarker
awwwwwww
Old Sep 25, 2004 | 08:09 AM
  #56
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
or it just ran low on oil
Trust me guys, it will not matter if you go SC, turbo, twin turbo, quad tubro, NA...the trick is:
1. select the right components for the job - especially fuel components. To properly do high HP forced induction (400 +), the car needs a return style fuel system with a healthy pump and a properly sized set of injectors.
2. tuning...best components in the world are just paperweights if its not tuned properly. Invest in some good datalogging equipment (wideband, some osrt of datalogger for ignition advance, etc) is a must for those looking to get reliable 400+ setups.
3. It could be a production date issue, but I suspect such issues would be on the revisions they have done to the ecu. Mechanicals, as far as I am aware, have remained the same, meaning that no date would be more/less safe to go FI with than another. However, the ecu map has been revised several times already. Since this serves as the baseline from where all tuning is done, this is where we should be focusing our attention IMHO.
Adam
Old Sep 25, 2004 | 09:36 AM
  #57
ihatethatbobbarker
theres also the fact that our rods suck... japan tuners have been saying anything over 400 kills the rods since they car came out.
Old Sep 25, 2004 | 10:12 AM
  #58
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Adam
i. The car was NOT low on oil for sure.
ii. It does a full fuel return system with a 255 L/hr fuel pump and a rising rate FPR.
iii. The ignition timing was datalogged on this car and was found to be 22 deg total advance at redline (this is an AT sedan). I was taking out 0.9 deg per PSI (and yes, this was not datalogged.... but the chances that the J&S was not taking out timing when it was set to do so are very slim to none).
iv. the ECU revision was AM603 (original was AM601). No difference among the two with respect to timing, only A/F (and I did have an AEM w/b meter... and the a/f was always in the low-11's at this boost level)
.... just wanted to clarify a few things wit hrespect to my case...
G
Old Sep 27, 2004 | 03:51 AM
  #59
mchapman's Avatar
mchapman
Jesus, yours was a freak accident.
Im not sure I would base any conclusions on this particular occurance.
Though I would still like to know.
Old Sep 27, 2004 | 03:26 PM
  #60
GurgenPB's Avatar
GurgenPB
UltimateSleeper
My engine failure may be related to the smoking issue I had. David of APS brought up a good point... it could have been that a piece of a piston was broken off b/w the two rings.... and even the relatively low boost could have just blown it (i.w. break up the piston).
G
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
