E-Manage -- throttle position?
Old Sep 21, 2004 | 03:31 PM
zimbo's Avatar
zimbo
Default E-Manage -- throttle position?
I have E-Manage and the Profec E-0 and I'm trying without much luck to scale my 380cc injectors to 650cc injectors. There are some places where I need to take out fuel and I'm assuming the only way to do that is to use the Air flow map.
However, AFAIK I am not tapping the throttle position signal. Is anyone doing that? If so, how?
Also, are the E-Manage maps additive? In other words, if I make changes to the injector map and the air map with they add?
--Steve
Old Sep 22, 2004 | 11:02 AM
ChrisMCagle's Avatar
ChrisMCagle
Zimbo,
For TPS functionality in the eManage, you need to connect the gray wire from the emange harness to Pin# 50 of the ECU. Here'a a diagram with that addition that I made:
350Z eMange wiring diagram
As for the maps being additive...
If you make a change to a number in the Injector map you are adding fuel to the mixture which will make your A/F richer, but if you change a number in the Air map you are adding air to the mixture which will result in a leaner condition.
Hope that helps
-Chris
Old Sep 22, 2004 | 11:27 AM
zimbo's Avatar
zimbo
Thank you! That is very helpful.
If only I had seen that info before deciding to take my RC injectors back off the car
--Steve
Old Sep 23, 2004 | 03:54 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Zimbo, trying scaling them a littel bit further.
Can you describe how your car runs? Idles? part throttle, light acceleration...wide open??
Old Sep 23, 2004 | 03:55 PM
Sharif@Forged
Forged Performance
Also Zimbo, you dont need to necessarily connect the TPS input. The map you are adjusting is MAF vs. RPM, and MAF is a good surrogate for TPS. You dont really need both. And since more people are tuning with MAF vs. TPS, there might be a better collection of MAF based maps floating around vs. TPS.
Just trying to help.
pslamp32
Feb 8, 2017 09:07 AM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
