AEM Wideband sensor...dead after 10000 miles?? :(
Old Oct 12, 2004 | 05:24 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Default AEM Wideband sensor...dead after 10000 miles?? :(
This sucks...do these sensors die this quickly? I was driving my car around, and noticed the guage was totally erratic. Off the scale lean and off the scale rich at idle...and cruise. I flooored it...and it went totally lean..and then again...totally rich.
I think the sensor is toast. Car runs exactly the same as before. Also dynoed it a couple days ago and my A/F was as expected. I mounted my sensor on the test pipe, which is too close to the turbo, according to the instructions....so I think I killed it.
Has this happened to anyone else?
I think the replacement sensors are 50-75 bucks.
Old Oct 12, 2004 | 07:46 PM
azrael's Avatar
azrael
Extreme heat definitely can kill them. The exhaust stream also does slow but permanent damage. If I recall correctly, those sensors usually have a life expectancy in the 30-50,000 mile range.
Old Oct 12, 2004 | 08:05 PM
PhoenixINX's Avatar
PhoenixINX
Wide-band sensors are usually VERY short-lived.
Per the reason the high end setup recommend NOT running them all the time.
That sounds a bit shorter than normal, might want to call AEM for their opinion... and possible replacement.
Old Oct 13, 2004 | 08:52 AM
t32gzz's Avatar
t32gzz
I went with the Tech Edge WBO2 for one reason... the replacement sensors are cheap. This is typical, in fact, mine went out 9k miles. I did some research before I bought it and found out that they die quickly, so the price of sensors is a large part of the cost of the WBO2. Sorry for the bad news.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
