Vortech Belt problems?
Old Oct 12, 2004 | 06:13 PM
aron's Avatar
aron
Default Vortech Belt problems?
I've had the vortech unit for about 6k miles now and the belt is beginning to wear, getting lots of whine....BUT i'm also getting a VERY VERY loud screaching (or scraping) sound that mostly ocurrs when I start up the car. This morning it was real loud for like 5 minutes....Is this the belt or the blower? Or is it something else? Or is the oil not getting to the sc? Did not sound good this morning. Im also getting a light but quick sputtering sound coming from beneath the engine bay below the engine which I have no idea what it is. Has anyone had this same sound. It almost sounds like a leak but i think something is worn out or about to break. Any help or info would be appreciated.
Old Oct 12, 2004 | 06:21 PM
gspot35's Avatar
gspot35
Default Re: Vortech Belt problems?
Might need a new serp belt. Also I corrected a squeak by PROPERLY torqing the idler pulleys. 23-28ft lbs, I did 28 since the load is more than stock.
Old Oct 12, 2004 | 07:29 PM
narkotic's Avatar
narkotic
these f#cking noises never go away... you tighten the belt, its cool but always comes back.. the design is horrible, serpentine belt is just way too big, ATI has it right i think w/ the two cog belts and shorter serpentine belt.. even when i get the belts right, the pulleys make noise when its cold for a bit..
Old Oct 12, 2004 | 07:36 PM
aron's Avatar
aron
Yeah, the whole vortech setup looks pretty wimpy. The belt is very long and narrow with the pulleys, everything seems to have to be perfect for the unit to be fully operational with no noise. A new belt costs 65 bucs as well. A damn belt! Im guessing its my pulleys making that loud screaching noise. Narkotic, is that what you think, or do you not get that very loud screaching noise at start up?
Old Oct 12, 2004 | 07:55 PM
narkotic's Avatar
narkotic
well i'ts hard to tell you unless i hear it... how old is your unit? they've since equiped it with a shorter serp belt, becuase the original one would eventually stretch out and coudln't tighten it anymore.. i've had my switched to the newer one but it's starting to get noisy again.. i'm pretty close to tearing the entire system out, i hate how noisy it is
Old Oct 12, 2004 | 08:15 PM
tig488's Avatar
tig488
a new belt is 30$, not 65$
Old Oct 13, 2004 | 05:10 AM
aron's Avatar
aron
damn, i was told $65 last night for a new serp belt. part #2A046-935 Please check.
Old Oct 13, 2004 | 05:27 AM
OldManZ350's Avatar
OldManZ350
See this Thread
Vortech Belt Slip/noise Solution-Fix Pics
Old Oct 13, 2004 | 06:16 AM
SungNamZ's Avatar
SungNamZ
Go to NAPA and get a replacement "serp belt". Part: V-Ribbed Belt #060935. Plus, better quality and half the price!
Old Oct 13, 2004 | 08:35 AM
mcduck's Avatar
mcduck
yep.. belt should be $30-$40... and that is almost certainly the problem.
After 6000 miles of hard work, it has gotten loose. You can probably work the noise out by tensioning it, but it will come back sooner every time. I just make a point to change both my Vortech belts every 5000 miles now as regular maintain. Squeek means slippage means lost HP!
Old Oct 13, 2004 | 08:49 AM
daddyz's Avatar
daddyz
Hey ti488, are you running 3.12 pulley? If so what gates belt are you using? I bought 2 belts from Vortech and wow the noise! What is the part #?
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
