Greddy owners, good news!
Old Nov 7, 2004 | 08:21 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
IS THE REFLASH FOR A 04??????????
Old Nov 8, 2004 | 10:31 AM
TECHNOSQUARE's Avatar
TECHNOSQUARE
Originally posted by Lorca@Z1
We are going to move the MAF from the typical TT kit location to right behind the drivers side inatke filter. The idea being that the air being metered is now un-heated and un-compressed and half of the total volume of air thereby reducing the likelyhood of maxing out the voltage.
Obviously since only half of the air is being metered there are some tricks that have to be played with the injector values (x2) so that you are getting the right A/F mixture. This has long been the sollution on the Z32 when a dual intake is required, usually for anything over 500rwhp.
I emailed Technosquare about our plans weeks ago but they never responded. Kenji at GReddy has been helping us out. Will post when we get some results with it.
I do believe that I emailed you back. I have to check my logs to double check that...
Old Nov 8, 2004 | 10:33 AM
TECHNOSQUARE
Originally posted by westpak
How does the reflash work with higher boost? Is it only for stock boost?
We are currently testing it for stock boost right now, but will have programs available for higher boost. Gary is one of the testers for higher boost.
TECHNOSQUARE
Originally posted by 350zDCalb
is this available for 04 350's??? production date 01/04??
i've been waiting...
We have the hardware coming right now for the 04's so we should have the flashes available soon.
Old Nov 8, 2004 | 10:38 AM
TECHNOSQUARE
Originally posted by accordfreak
it's an option i'm definitely willing to take if you are able to tune it fully yourself..
Is it simliar to the do it yourself tuning software by www.hondata.com for hondas?
any prices available?
Originally posted by zillinois
You could program it yourself, but the real problem for the average tuner is cracking the ECU. Knowing what you are changing is a problem until you understand where everything is in the ECU and what its for. If you think about this post even, they have just now figured out how to control the injectors after 2+ years of hacking. Unless you have that kind of skill, the programmer would turn into an expensive paperweight. Or at the very least requires months of your time to figure it all out. It think the Techtom unit is $5000. I doubt they'd give you that hard earned information because it separates them from other tuning shops with the Techtom.
Originally posted by Z1 Performance
exactly..the price for the software is higher than nearly every full standalone out there. The data it gives you is also very complex and basically looks like randowm numbers in a series of charts - it is not desinged as a GUI, or for the end user - it was desinged to be offered to a tuning shop.
Zillinios and Z1 Performance hit it right on the spot.
Old Nov 8, 2004 | 10:49 AM
redline tt's Avatar
redline tt
keep me informed as well..
Old Nov 8, 2004 | 11:13 AM
Lorca@Z1's Avatar
Lorca@Z1
Sounds good Brian, we would appreciate your input on this.
Old Nov 8, 2004 | 11:19 AM
TECHNOSQUARE
Originally posted by webcarconnection
question a little off topic but your reflash for the Turbonetics kit can handle more mod on the Z (like the ones in my sig. except the Nitrous kit of corse)
thanks in advance!
I don't quite understand this question.
Old Nov 8, 2004 | 11:20 AM
TECHNOSQUARE
Originally posted by was wesman
Since you can now control the RC 440's , will you be offering it with the ATI reflash ? I am running a 9# pulley and planned on getting the ATI reflash from you and running an emanage to scale your 380cc flash with it.
If you can flash for the 440's now, I can eliminate the emanage all together. Please let me know, I want to get this done ASAP.
--wes
We can reflash with the 440cc and the ATI reflash program.
Old Nov 8, 2004 | 02:31 PM
webcarconnection's Avatar
webcarconnection
The question is: Do you have to do another tunning besides the one you have for the Turbonetics Kit if the Z already have more mods like Cams, Plenum, ect.
Thanks!
Old Nov 8, 2004 | 03:05 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Two other options are either installing a different MAF sensor (the eManage has provisions for using upgraded MAF's), or you could ditch the input from the MAF altogether and just tune off manifold pressure. The Profec e-01 includes everything you need to make the switch, except for a $19 boost signal harness from the eManage to the Profec brain. The Profec comes with a high quality 2 bar MAP sensor which is more than enough for our purposes.
Essentially, when the car is idleing and cruising, the MAF signal is used by the ECU to controll fuel/timing. When under boost, and positive vaccum, the eManage controls the fuel engrichment and timing reference the pressure sensor and RPM. Its a pretty clean and accurate setup...with minimal hassle.
Emanage still keeps the MAF voltage clamped at 5V...so the ECU never sees more than that...and can never goto limp mode.
Old Nov 8, 2004 | 03:45 PM
TECHNOSQUARE
Thanks!
Yes, we do have other maps that we can use with your mods if that is your question.
Old Nov 8, 2004 | 04:07 PM
TECHNOSQUARE
Oh, one more thing. As for testers, we're still looking for a 350Z with the Greddy TT with stock exhaust and stock cats. We need a stock program.
Old Nov 8, 2004 | 05:42 PM
Aloharacing's Avatar
Aloharacing
Great news, Brian.
Be sure to keep us informed of progress and potential cost.
Old Nov 8, 2004 | 06:54 PM
was wesman's Avatar
was wesman
Cool...I assume it will compensate for my mods? or will you need to tune additional parameters?
Currently the performance mods that affect AF are :
Xerd long tube headers (replaces cats as well)
Stillen Dual Exhaust
Crawford Plenum
ATI SC with 9# pulley
Also what is the turn around time ?and what happens if it pings or is running lean ? send the ECU back in ??
I am also considering a front mount NX intercooler chiller (shoots nitrous on the IC) for track use. I'm not certain the best way to control it, perhaps have an AFC to piggyback and tune or will the ECU compensate for it ?
--wes
--wes
Old Nov 8, 2004 | 09:09 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
BRIAN---
please pm me when the 04 reflash is available
THX
Old Nov 9, 2004 | 09:34 PM
webcarconnection
Brian, the Turbonetics Kit is on his way... Technosquare have the reflash ready for this kit?
Thanks!
Old Nov 10, 2004 | 03:33 PM
  #38
TECHNOSQUARE
Crawford Plenum
--wes
--wes
We are able to do a program for basically anything that isn't super heavily modded without having the car here. So for your list, we can do a flash for you. For best results, a dyno with an A/F chart sent in with the ECU would help give a more accurate tune. If it pings or is running lean, send it back in and we will fix that.
I don't remember if the Procharger has the MAF before or after the intercooler. But if the MAF is after the I/C, then the computer should automatically compensate for the NX intercooler chiller.
Old Nov 10, 2004 | 03:36 PM
  #39
TECHNOSQUARE
BRIAN---
THX
Hardware should be here any day.
Old Nov 10, 2004 | 03:47 PM
  #40
TECHNOSQUARE
Thanks!
Far as I know, I didn't think Turbonetics' kit was shipping out yet. You might want to double check on whether you just pre-ordered or if the kit is being shipped already.
