I drove the TurboNetics Single Turbo 350z!
Originally posted by AmyCroft
Which will get Carb Certification? It would be a pain to put the car back to stock every two years to pass Smog Check.
Cheers Amy
Cheers Amy
This was one of the positivies about this kit is that it's only 8/10 hours install.
Not too bad for return to stock.
I have no idea what I am going to do if APS doesn't get carb.
Trust me, I know the things that you "can" do, but there is no guarantee that will always work/be an option.
The odds are pretty high that if I have to yank my kit, it's not going back in.
Originally posted by MIAPLAYA
We should find out soon enough. My and alpine are planning to get some Dynojet dyno time in side by side to see what these things can do.
Originally posted by Enron Exec
That would be very helpfull in getting a close to final verdict for alot of potential FI buyers. Hope you guys can do a couple of runs and make a new thread. This is sooo very interesting.
, don't you wanna be happy too?
I got my kit re-tuned for cold weather road & track, I now have 377RWHP a little more power, a little sooner. This will be map #2, and then I will need a another map for 100 octane.
It's hard not to spin my current tires at the top of 1st, and the 2nd half of 2nd is almost as likely.
I have gotten a few more launches in, and it's just incredible.
As Joe mentioned earlier in this thread we drove each others cars. I have the opportunity to drive a couple other twin 350Z turbo systems on the market and I must say I was most impressed with his APS twin system. Drivability was good all the way through the RPM band, no hesitations, no bogging good turbine response. Overall a well put together system and my hat goes off to Peter and the boys at APS for a job well done.
If a twin turbo system is what your after this is certainly a good choice.
Brad
Brad
Brad
Brad
I think some may have taken some of my previous engineering based comments out of context. As you know a I have a great deal of respect for Turbonectics and that we have a genuinely friendly relationship.
I wish you every success. The 350Z FI market is a very exciting place to be at the moment and we both know that there's plenty of opportunity for all of the good guys in the FI industry.
Regards
Peter
Originally posted by alpine
ditto here on not being a dyno guru.
the trq numbers should be similar as they are just calcs based on acceleration and hp. thats what i'm guessing at.
i'm sure if someone would take a shot at the interet, thw formula is there.
i'd do it but i am holding my baby at the moment and typing with one hand, which is killing me, on a split keyboard.
gotta go
gotta go
hp == tq(rpm/5252)
See here and second to last link off that page, here.
One of the implications of the equation is that horsepower/torque curves always cross at 5252. You'll notice in the posted dyno's, that is not the case. As this is a rather fundamental problem with the charts, the only fair way to interpret them is to throw them out, and wait for others.
Of course, none of this takes into account the conversations going on about relavance of one dyno's results to the other. What I always interpreted the issue to be was peak hp/tq numbers being different. It never really occurred to me that the chart shapes would/could be different. It makes perfect sense given that the different dyno types use different methods to simulate loads, and they have their own 'profiles' to them, impacting what the chart looks like. I guess I just never really thought about that. However, given the formula above, all a dyno really is measuring is torque samples at intervals, and splicing that together into a torque curve chart. A little simple math (from formula above) generates corresponding hp figures for each torque data point. The point is, some kind of reference load must exist so that they put it on a dyno to ensure it is accurate across its 'rev' range. I don't understand why dynos should read differently - it seems should be a standard way of testing the dynos and documenting their accuracy. I can only assume the reality of physics throws a monkey wrench into what is obviously a simplification of the facts.
What i've always been told is that dynojet dyno's are the most accurate dyno's, mustang dyno's tend to rate lower on hp and tq, and dynapack's just depend, but they are usually off. So I would say if we want reliable numbers we are going to need a dynojet dyno comparison. BTW, I am very interested to see these kits compared, i've been waiting for a turbo kit shootout.
Originally posted by amolaver
I'm certainly no expert, but what I see as wrong with the dyno numbers earlier is the equation I believe used to determine hp - namely:
Originally posted by flynnibus
Didn't find the dynos quickly to see.. but typically you'll find on dynos posted where the lines do not cross at 52xx is because the scales of the hp and tq are different on the graph. When that is the case, they will not intersect at 52xx. Check the zero points and scale of hp and tq, if they are different.. that's your answer.
So long as hp and tq are on the same chart, and the y-axis is RPM, even if the x-axis has different scales for hp or torque (essentially manipulating what the hp or tq curves look like by artificially compressing or expanding them), they should still cross at 5252 rpm. I don't think I've ever seen a dyno where the scales were different like this, but I can't think of what else you mean.
S12 - explain what you're saying. What difference does the scale differences of one axis make when the other is constant - it doesn't.
My example above is partly confusing - I should have used x-axis for RPM and y-axis for hp/tq, but it doesn't really matter (the point is the same either way). If the x-axis is RPM, regardless of what the y-axis does, a proper hp/tq curve is going to cross at 5252 rpm. If it doesn't something is either wrong, or worse.
ahm
ahm
Alpine...my car should be done soon. When/where you want to meet for a dynojet comparison.
I'd like to see that first so that we can take each other’s "proprietary" dyno results, before we go to a common/neutral one.
Also I had mentioned to Brad I'd like to run my car on the DynaPack for info also.
I didn't get a response on that, and as I know he is busy, I didn't press.
I missed a DynoJet run myself Saturday, My father went into the Hospital friday 1:00AM and we were there for 2 days. He's out now, waiting on results, and need to go back for further consultation.
After I get these items under control, I would love to get together.
Did you have any suggestions? Where are you located? I'm in San Fernando.
You must have a dyno now, right? What was that dyno done on? Was it the same DynaPack that Brad/TurboNetics used?
ahm
ahm
ahm
ahm
Assume the intersection at 52xx is 200. 200 hq and 200 tq at the same RPM value.
If the HP scale goes from 0-200, this point is at the top of the chart for HP curve. If the TQ scale goes from 200-400, this point is at the bottom of the chart for the TQ curve. Both values being identical, but they do not interesect because the y axis for each line is different. That is what is meant by the scales of the axis being different. That's an extreme example to illustrate the point, but the concept is the same. if the Y axis are not the same, the two lines will not intersect at 52xx.
ahh. I think I see now. Stupid me.
Maybe I just never looked closely, but I don't think I've ever seen a dyno graph like that (not as extreme as your example, just where the scaling was different for hp/tq).
Sorry S12 - I just didn't 'see' it before. Now I do, and sit corrected
ahm
ahm
etkms
Jun 19, 2022 06:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
FromGtoZ
Sep 20, 2015 03:41 PM
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
