Rough Engine @ 4000RPMs
Old Dec 27, 2004 | 09:52 AM
AmateuRN's Avatar
AmateuRN
Default Rough Engine @ 4000RPMs
I have a 2004 5AT with 3500miles on it... If I am in 1st or 2nd gear and let the RPMs biuld slowly, not flooring it or anything just shifting later in Manual Mode as the needle passes 4000 the car seems to get rough and then smooth out. Its only lasts as the needle passes the 4K mark so it's not even a second long, its very fast, but noticeable. Whats up with this? Should I be worried? I have never noticed it before and I 've had the car for around 3 months.
The only other ways I can describe this feeling at 4K is a hesitation, or like the car hits a bump....
Also, if I do floor it the shifts are smooth and crip and everything is smooth throughout the entire powerband....Thanks in advance!
Old Dec 27, 2004 | 10:26 AM
FLZ's Avatar
FLZ
Just a thought, Maybe O2 sensor needs checking? Either way, that's what the warranty is for......GL2U....Dave
Old Dec 27, 2004 | 01:29 PM
AmateuRN's Avatar
AmateuRN
I did put the AEM intake on about 3 weeks ago....I'll check, any other ideas? I have to take my cars 4 hours to get it checked out...will a nissan place in town be able to do it?
Old Dec 27, 2004 | 10:21 PM
tware's Avatar
tware
mine does it too (03, 16K miles). only if I've been messing around in MM mode. that tells me its an ECU/TCM thing. Lots of other people have mentioned the same thing. Its odd, but I dont think its anything mechanical to worry about.
Old Dec 30, 2004 | 04:28 PM
JonsilvZ's Avatar
JonsilvZ
I dont have this problem when in MM. But it does get louder and deeper pass 4k rpm which is good
Old Dec 31, 2004 | 12:34 PM
milos's Avatar
milos
sorry ...but what is MM mode?
Old Dec 31, 2004 | 07:16 PM
s4m222's Avatar
s4m222
i think MM mode is when u put the shifter into the manual shift thing, manumatic mode... in the auto when u control the shifts...
Old Jan 5, 2005 | 09:55 AM
luvmyG35's Avatar
luvmyG35
Thats your "VTEC". Or is it called vvtc or something like that.
Old Jan 5, 2005 | 03:45 PM
Poptarts's Avatar
Poptarts
Building on what he said^^
At 4000 rpm the ECU resets the Air/Fuel maps to be more agressive and more responsive. i noticed on the dyno charts mostly. I also notice this everyday whenever i drive in A/T or MM it still happens. Its sorta like Honda's V-TEC or Toyota i-VVT.
liqalu04
Jan 2, 2022 12:58 PM
hulkout
Apr 28, 2017 09:00 PM
ablaine
Nov 29, 2016 10:13 AM
Fixxxercask
Nov 9, 2015 11:10 AM
