Help with audio setup
Old Dec 27, 2004 | 12:14 PM
lucidazn's Avatar
lucidazn
Default Help with audio setup
Infinity Kappa 63.5i 6-1/2" $119.99
Product Description:
* Plus One C.M.M.D. woofer cone
* hi-roll rubber surround allows greater woofer movement
* 1" C.M.M.D. dome tweeter
* 1-1/8" metallic planar EMIT supertweeter
* 2-way external crossovers (18 dB/octave, 3,500 Hz high- and low-pass)
* sensitivity 90 dB
* frequency response 45-22,000 Hz
* recommended power range 2-75 watts RMS
* peak power handling 225 watts
* top-mount depth 2-3/16"
* adapter rings for 6-3/4" applications included
Infinity Perfect 6.1 6-1/2" Component System $349.99
* Kappa Perfect 6.1 - 6-1/2" Component System
* Power Handlng: 400 watts Peak / 100 watts RMS
* Impedance: 3 Ohms
* Deep-anodized aluminum woofer cone for incredible detail and accuracy
* 1" edge-driven aluminum tweeter with rubber surround
* -Mount™ Tweeter Mounting System: for Angled, Flush, or Surface Mounting
* Component crossover: Linqwitz-Riley with 3.5kHz tweeter crossover freqency, and -4 / 0 / +5 dB tweeter level control
Speaker Specifications:
* Speaker Size 6-1/2"
* Design 2-way Component System
* Sensitivity 90dB
* Frequency Response 75Hz - 23kHz
* Peak Power Handling 100 watts
* RMS Power Handling 400 watts
* Impedance 4 ohms
* Top Mount Depth 2-3/4"
* Bottom-mount depth N/A
* Cutout Dimensions 5-1/16"
Infinity Kappa 693.5i 6" x 9" $139.99
* Plus One C.M.M.D. woofer cone is 30% larger than other speakers of this size, ensuring strong bass response
* high-roll rubber surround allows greater woofer movement
* sensitivity 90 dB
* frequency response 35-22,000 Hz
* recommended power range 2-110 watts RMS
* peak power handling 330 watts
* top-mount depth 3-1/4"
Infinity Perfect 10.1 10" Subwoofer $154.99
* aluminum cone
* high-roll butyl-rubber surround
* massive cast-aluminum basket
* suitable for free-air use (handles up to 175 watts in free-air applications)
* recommended power range 75-350 watts RMS
* peak power handling 1,400 watts
* frequency response 18-200 Hz
* sensitivity 94 dB
* top mount depth 5-3/4"
* sealed box volume: 0.6 cu. ft.
* ported box volume: 1.0 cu. ft.
JL Audio 300/4 (4 channel amp) $359.99
Specifications:
* Rated Power (stereo): 75W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
* Rated Power (bridged): 150W RMS x 2 @ 3 ohm-8 ohm (11V-14.5V)
* THD at Rated Power: <0.03% @ 4 ohm
* S/N Ratio*: >108.5 dB below rated power
* Frequency Response: 5 Hz-30 KHz (+0, -1dB)
* Damping Factor: >200 @ 4 ohm per ch./50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
Features:
* Differential-Balanced Input Topology: (2 pairs of inputs)
* Front Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
* Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
* Speaker output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
Amplifier Specifications:
* Number of Channels 4
* RMS Power (4 ohms) 75 watts x 4 chan.
* RMS Power (2 ohms) 75 watts x 4 chan.
* RMS Power (1 ohm) (at 1.5 ohms) 75 watts x 4 chan.
* Bridged RMS Power 150 watts x 2 chan.
* Peak Power Output 600 watts approx.
* Min. Impedance Unbridged 1.5 ohms
* Min. Impedance Bridged 1.5 ohms
* THD @ Rated RMS Power 0.03%
* Speaker Level Inputs No
* Amp Preamp Outputs Yes - 1 pair
* Built-in Crossover HP/LP (50 - 500Hz)
* Bass Boost Bass EQ (on/off)
* Signal-to-Noise Ratio 108.5 dB
* Fan Cooled N/A
* Fuse Rating 40A
Infinity 310a Reference Series 374w @ 1ohm (monoamp for sub) $179.99
* Infinity reference series 310a car audio subwoofer amplifier
* RMS power rating 116 watts x 1 at 4 ohms / 312 watts x 1 at 2 ohms
* Peak power output: 347 watts x 1
* 12dB built in, variable low-pass electronic crosover
* Dynamic Bass Optimization circuit (high- and low-pass filters, variable from 20-40 Hz)
* Optional wired level control
* Fuse rating: 30A x 2
* Dimensions: 11-7/16"W x 2-11/16"H x 12"H
* Number of Channels 1 - Mono
* RMS Power (4 ohms) 116 watts x 1 chan.
* RMS Power (2 ohms) 312 watts x 1 chan.
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power Not Bridgeable
* Peak Power Output 347 watts
* Min. Impedance Unbridged 2 ohms
* Min. Impedance Bridged Not Bridgeable
* THD @ Rated RMS Power 1.0 %
* Amp Preamp Outputs Yes - 1 Pair
* Built-in Crossover LP (32-320Hz)
* Bass Boost Variable bass boost
* Signal-to-Noise Ratio 81dB
* Fan Cooled No
* Fuse Rating 30A x 1
Flux capacitors...
How many do I need? One for each amp? How many watts for the flux capacitor(s)?
Fuse
Do I need some sort of a fuse box just incase a power surge occurs and shorts out my system? What would I get? Voltage/wattage rating?
This is what I am looking at. I am a big complete nub to this stuff. I am wondering if this is a good set up and if they go together well. I want something that has good hi's, and ok mid's (hopefully the woofer can compensate). I really like to listen to hiphop, techno, classical and rock. What I want is crisp and accurate music, with a nice punchyness to the bass. So please, someone help me. Thanks.
Old Dec 27, 2004 | 12:38 PM
SupraTTurbo's Avatar
SupraTTurbo
Flux Capacitor?? Are you building a time machine.
Old Dec 27, 2004 | 01:26 PM
Dragonstyle's Avatar
Dragonstyle
Old Dec 27, 2004 | 03:15 PM
lucidazn's Avatar
lucidazn
Farad Capacitor... same thing! Flux came to my mind when I thought of the capacitor.. God knows why.. hahah. A G35 time machine would be awesome.
Anyways BACK TO MY TOPIC PLEASE!! =)
Old Dec 27, 2004 | 03:32 PM
JCat's Avatar
JCat
Refueling the DeLorean's Flux Capacitor..............
"In order to generate the 1.21 gigawatts of electricity needed to power the DeLorean's Flux Capacitor, Doc uses a nuclear reaction produced by some plutonium he "acquired".
The one flaw in this design is that the driver must carry enough plutonium to travel from point A to point B in the timeline. One plutonium pellet = One trip. "
Old Dec 27, 2004 | 03:46 PM
lucidazn's Avatar
lucidazn
Um.. thanks..
Old Dec 27, 2004 | 04:11 PM
JCat's Avatar
JCat
Nazar at
http://www.wickedcas.com/index.php?o...a61bf973bcafcd
strikes me as the most knowledgable about capacitors.
see also:
https://my350z.com/forum/showthread....threadid=44359
350Z_Al
Oct 29, 2020 07:44 PM
jlb
Oct 15, 2017 05:10 AM
bcoffee20
Nov 19, 2015 06:39 PM
