What Are The (+/-) In A 3 Piece Over A 2 Piece Rim?
Old Apr 30, 2005 | 02:04 PM
marques's Avatar
marques
Default What Are The (+/-) In A 3 Piece Over A 2 Piece Rim?
I Have A Set Of Iforged Daytona On Order(3 Piece Rim) 20's. Im Thinking About Go To A 2 Piece, So I Was Just Wondering What Are The Positives & Negatives In A 3 Piece Over A 2 Piece Rim.. I Know Weight & Price. Is There Any Other?
Old May 2, 2005 | 01:04 PM
marques's Avatar
marques
bump^^
Old May 2, 2005 | 03:56 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
look
Old May 2, 2005 | 09:11 PM
nisco's Avatar
nisco
weight?
Old May 2, 2005 | 09:46 PM
mgl's Avatar
mgl
offset
Old May 10, 2005 | 12:35 PM
JimRHIT's Avatar
JimRHIT
the three piece is (+1) piece vs. the two piece
the two piece is (-1) piece vs. the three piece
Old May 10, 2005 | 01:01 PM
protocav's Avatar
protocav
back in the day, when wheels were made out of steel, a three piece was lighter, because the barrel was steel, and the face could be made out of aluminum. since wheels now are made out of aluminum, there really is no advantage, unless you plan to run a magnesium face. i have 2 piece iforged wheels, and i made damn sure that they looked exactly like the 3 piece that i saw. i have never regretted going with a 2 piece. the two piece and three piece should weigh the same, because they are made out of, essentially, the same quantity of material.
additionally, since it is so hard to mount tires on iforged wheels, due to the reverse barrel design, many tire shops will have to use high pressure to seat the beads. this high pressure can easily damage the o-rings or gaskets that seal the two halves of the barrel on a three piece wheel.
i guess the only advantage would be that you could replace the outer lip if you damaged it badly, instead of getting a whole new rim.
hope that helps, save yourself some money.
Chad
Old May 10, 2005 | 01:05 PM
GQ 350z's Avatar
GQ 350z
If you go 3 piece, you can paint/powder coat the interior part of the rim by taking it apart.
Other than that, owning 3 piece wheels will help you sleep better at night.
Old May 10, 2005 | 02:35 PM
protocav's Avatar
protocav
that's a good point that i forgot about.
Old May 18, 2005 | 02:55 PM
Sundeviljay's Avatar
Sundeviljay
If you curb a 3-piece, you can just have that piece replaced....very in-expensive...
ablaine
Nov 29, 2016 10:13 AM
