traction control on my G35 needs unarmed....
does anyone have any idea on how to disconnect the traction control on the G35s.... so much for the cute little rocker switch but how does one really really stop the computer from taking control of the rear wheels???
get this traction control module(VDC Memory) from KP technology
http://www.kptechnologies.net/
Normally when you turn the car on and turn off the VDC, when you turn the car off and then on again the VDC turns itself back on. However with this module, when you turn off VDC it will stay off whether you turn the car off and on until you turn it back on.
Hope this helps,
Jay
Hope this helps,
Jay
G sensor should have a Bosch label on it. Just unplug the pigtail harness that goes to the sensor, and you should be golden.
You'll have to either just start unbolting the center console so you can lift it up, or look it up in the ESM. Not too terribly difficult. If you want, you can even wire a little switch to the plug so you can have your own, full VDC disable switch.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
CFAUVEL
Oct 1, 2015 03:20 PM
