Change rear diff fluid at what mileage?
Old Jul 6, 2005 | 11:11 AM
yacoub's Avatar
yacoub
Default Change rear diff fluid at what mileage?
Curious if that's something to get done soon. I have just over 11k miles and am taking her in for an oil change tomorrow.
Thanks.
Old Jul 6, 2005 | 12:50 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I changed mine at 10k miles, it has metal shavings.. I guess you can change it anytime, but they are totally enclosed anyway, so it won't get dirty like engine oil..
Old Jul 6, 2005 | 04:39 PM
n8vz's Avatar
n8vz
changed it at 16K, after looking at the metal shaving..maybe I should have changed earlier (like 5K). Changed it with Royal Purple Max Gear 75W-90.. now the rear diff runs better then ever!
Old Jul 6, 2005 | 05:03 PM
myehrick09's Avatar
myehrick09
How hard is it to change the rear diff. fluid? Step by step would be nice to all do it "yourselfers" outhere.
Old Jul 6, 2005 | 05:12 PM
willthethrill's Avatar
willthethrill
Yeah, what he said ^
Old Jul 6, 2005 | 06:43 PM
Monsta's Avatar
Monsta
I JUST changed mine today. It was easy to do but I didn't write anything up. I will take some photos tomorrow and post some instruction ASAP.
Old Jul 6, 2005 | 08:39 PM
accordfreak's Avatar
accordfreak
When should you change the transmission fluid at? 15k?
I changed my diff oil at 5k.. lots of metal shavings
Old Jul 6, 2005 | 09:02 PM
islandsnow's Avatar
islandsnow
it's really easy if you can get under the car, with a lift. Theres a lower drain plug at the back bottom of the diff, you need a hex wrench to get it out, but just undo it and let it flow out. Once it's all drained out, there is another fill plug a little higher up, take that out and pump the new fluid in to the fill plug level. That's it.
Old Jul 6, 2005 | 09:28 PM
n8vz's Avatar
n8vz
what you need are
1)a way to lift the car up (leveled)
2)the right kind of differential fluid
3)10mm Hex socket
4) 2 X crush washers
5) a hand fluid pump to fill the tranny fluid
Old Jul 7, 2005 | 04:28 AM
Monsta's Avatar
Monsta
Default Changing the Differential / Transmission Oil
Instructions
Old Jul 7, 2005 | 06:40 AM
Cactus's Avatar
Cactus
What does the dealer charge?
Old Jul 7, 2005 | 12:08 PM
yacoub's Avatar
yacoub
I dunno but they said not 'til 60k so I didn't bother getting it done today.
Old Jul 7, 2005 | 02:26 PM
myehrick09's Avatar
myehrick09
Originally Posted by Monsta
Thanks for the instructions bro
Old Jul 7, 2005 | 04:02 PM
willthethrill
Nice write up!
are the crush washers the same ones that you can buy for the engine oil drain plug?
Old Jul 7, 2005 | 05:02 PM
Monsta's Avatar
Monsta
Not a problem all.
Willthethrill-I am not sure. I didn't size em up. I used the same washers w/ no leaks though.
burglapfd
Dec 6, 2020 01:04 PM
hulkout
Apr 28, 2017 09:00 PM
Stevo Z
Oct 3, 2015 09:14 PM
