Another dissappointing dyno...
Old Aug 12, 2006 | 01:03 PM
ZFreak (Denver)'s Avatar
ZFreak (Denver)
Default Another dissappointing dyno...
What gives with our cars?
My procharger is off at ATI getting fixed, so here's the mods...
TurboXS UTEC + Map switch (dynoing on 91 premium at 5300' altitude)
Crawford plenum
Helix TB spacer (not plenum spacer, TB spacer)
Intake
Stillen SS Headers
Stillen True-dual exhaust (stock cats)
That's it.
228rwhp and 219tq. 102 degrees out...that was the best of 8 runs when tuning my UTEC for N/A with a pretty agressive tune. Why are these numbers so low? The dyno place was telling me that typically 350z's in stock form make about this amount of power. What's wrong?
Old Aug 12, 2006 | 01:06 PM
kourosH's Avatar
kourosH
dont some people have higher horsies stock??
Old Aug 12, 2006 | 01:10 PM
rlwjr1's Avatar
rlwjr1
Are those numbers corrected??? 5300' and 102* temps wreak havoc on a motor.
Old Aug 12, 2006 | 01:18 PM
ZFreak (Denver)
SAE... That's flat out what it got at the wheels on a dynojet. I'll post the dyno sheet here shortly.
Old Aug 12, 2006 | 01:32 PM
captron61's Avatar
captron61
Those mods you listed aren't worth alot of hp. A tuned UTEC should net you a little extra hp, but overall not alot. Mods you listed at your altitude on a 102 degree day=what you pulled. Take it back when it is about 75 degrees and you should see the hp increase you are thinking you should make.
Just my 2 cents, been down the heavily modded road before.
Old Aug 12, 2006 | 01:35 PM
ZFreak (Denver)
Ok. Thanks. Other mods (while ATI is repairing the procharger) planned are JWT clutch/flywheel, UR pulley, HKS DLI, and Crawford cats.
Something's wrong... numbers are too low.
FWIW, the baseline, untuned pull was like 208hp/199tq
Old Aug 12, 2006 | 02:04 PM
rrdugas's Avatar
rrdugas
not at 5300 ft and 100+ temps. and what about the pressure in that climate
Old Aug 12, 2006 | 02:31 PM
superchargedg's Avatar
superchargedg
Damn Noobs
dude you are a mile up in the atmosphere,those #,s are about right.even at sea level the auto g,s make crap for power.
Old Aug 12, 2006 | 06:41 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Where did you get dynoed? Also who did your tune? I've dynoed at 249 & 236 SEA corrected at Mac w/ PopCharger, UR Crank Pulley, Motordyne 5/16th Spacer, & APS 2.5" TP. My Base line was 232 & 226. I can't view your dyno shet but I have a feeling that your posting uncorrected numbers.
Old Aug 12, 2006 | 07:48 PM
ZFreak (Denver)
Nick at MAC did the install of UTEC and tune. Uncorrected was like 173hp or thereabouts... He knows his shiznit, and agreed that maybe my procharger had taken it's toll on the engine. (i.e. low compression)
Old Aug 12, 2006 | 09:04 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Really??? Nick does know his shyt. He is one of two tuners I'm considering to tune my Z when I return. It just doesn't sound right. What do stock G35 dyno at? Hopefully we can figure this out and get some hp out of your car.
Old Aug 12, 2006 | 09:55 PM
arjunz's Avatar
arjunz
i made 230 HP stock! .. every car is different..
Old Aug 13, 2006 | 05:07 AM
Gsedan35's Avatar
Gsedan35
Is this a auto or manual car?
Old Aug 13, 2006 | 06:47 AM
rythex's Avatar
rythex
I'm assuming it's a manual since he's putting a new clutch / flywheel in.. ;p
Old Aug 13, 2006 | 07:50 AM
Gsedan35's Avatar
Gsedan35
Ok, that's a couple of post's below the first one, thanks.
Old Aug 13, 2006 | 01:22 PM
ZFreak (Denver)
Yeah manual trans.
Which gear is 1.00:1? 3rd or 4th? Should be 4th, right?
Old Aug 13, 2006 | 01:54 PM
Kenk2's Avatar
Kenk2
Professional
Yeah manual trans.
You want to Dyno in 5th. Gear bro.. Did you do it in 5th.?
Old Aug 13, 2006 | 10:38 PM
ZFreak (Denver)
I think he did it in 3rd for most of them, and then a 4th gear under heavy load at the very end. DOH... Nick should know better. He's installed 50+ UTEC's and tuned every single one of them on 350Z's... I was their 1st G though.
Old Aug 13, 2006 | 11:12 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
The reason Nick dynos in 3rd & 4th gear is... If you dyno in 5th it takes longer to go from 2k rpm to redline. This in turns warms the engine up more and warm engine losses power. We acually test this theory and there is a mild lost when dynoing in 5th & 6th gear.
Old Aug 14, 2006 | 12:36 AM
ZFreak (Denver)
...but a 5th gear pull would be more accurate, correct?
