LED clear corner plus blinker teaser
Old Jan 8, 2007 | 08:33 PM
MidnightG35X's Avatar
MidnightG35X
Talking LED clear corner plus blinker teaser
So here's some pictures (assuming I get them to show up here) of my LED clear corners that incorporate the blinkers. I know its probably not the same as the ones from clearcorners.com, but I also felt like spending $50 instead of $305 on mine. They just need to be mounted a little better on the inside, connect the wires, glue it back up and then done! It has been a pretty fun project so far besides the lead solder fumes. I'll get some videos and pictures of it installed this weekend.
Front side of the circuits:
Back side of the circuits:
Completed front minus some small mounting things and being sealed back up:
Completed back minus being sealed back up:
All lit up! The bottom row of LED's will only be on with the blinkers, but for testing this works.
Until this weekend, enjoy.
Old Jan 8, 2007 | 09:40 PM
mr. sparco's Avatar
mr. sparco
Looks sweet, do the lens and the white plastic back come apart? I have a 350z so I don't know.
Old Jan 9, 2007 | 05:07 AM
MidnightG35X
They do if you coax then a little bit. They are just glued together, so I took a dremel to the side of it originally, then pried it up the rest of the way with a screwdriver as recommended by a DIY over at g35driver.
350z82
Oct 1, 2015 06:25 PM
