DIY Video Series
Old Nov 4, 2007 | 09:03 AM
ByThaBay's Avatar
ByThaBay
Default DIY Video Series
I've got a bunch of DIY videos that I made / (am making) for the G35 & 350z
I try to keep the main links updated here:
http://g35driver.com/forums/showthread.php?t=183421
some of the videos up there are:
the videos include:
Tire rotation
Brake fluid flush
Clutch fluid flush
Engine air filter replacement
In-Cabin air filter replacement
Throttle body cleaning
Throttle body Coolant Bypass
Engine oil & filter change
Differential oil change
Manual transmission oil change
Coolant Drain & Refill
Spark plug replacement
Power Steering System Flush and Magnefine In-Line Power Steering Filter Installation Procedure
Jackin' the G Sedan
Jackin' the G Coupe
Sedan front bumper removal
Headlight bulb replacement(non-projector type)
Front brake job
Front brake job (2003 Brembo Coupe - everything turned out ok, but this is the WRONG way to do brakes)
Rear brake job
Replacing drive belts
Motordyne Plenum Spacer Install
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Twenty4
Jan 17, 2016 01:20 PM
