GReddy turbo install, now no start
Old Dec 18, 2007 | 02:00 PM
EnduroMTS's Avatar
EnduroMTS
Default GReddy turbo install, now no start
Hey, i just installed a GReddy turbo kit on an 05 G, and now it don't start. The coils are not getting a signal to spark. I've exhausted everything I can possibly check without a Consult-like scan tool. There are also no codes, all fuses are good, there's voltage to all the sensors. Its getting fuel and the MAF is good.
Think it could be a cam or crank sensor? Thats what i'm leaning toward but i need something to check their patterns. Any ideas?
Old Dec 18, 2007 | 03:10 PM
TSG-Z's Avatar
TSG-Z
I think the FI section would better answer this question. Good luck
Old Dec 18, 2007 | 05:08 PM
civic4982's Avatar
civic4982
battery?
Old Dec 19, 2007 | 10:41 AM
SpeedRcr's Avatar
SpeedRcr
if your crank sensor is out it will crank over and act like a dead battery...did you check that everything is buttoned up?
Old Dec 21, 2007 | 10:45 AM
EnduroMTS's Avatar
EnduroMTS
Yeah, all the electrical, the emanage. Even disconnected everything to the emanage to see if it would start on just the ECU but still nothing. It cranks strong, just no signal to the coils. I've checked all the grounds to make sure they were bolted in & w/ a power probe to make sure they were actually grounding. I thought it may be a bad crank sensor so i put a good one from a 350Z in and still nothing.
Old Jan 3, 2008 | 10:06 AM
EnduroMTS's Avatar
EnduroMTS
So i got the tranny out and checked the flywheel dowel pins, and it was off by 1 hole. So whether thats the culprit of the no start is still yet to be seen but we'll know for sure once we put everything back together.
Old Jan 3, 2008 | 11:50 AM
06Gcoupin's Avatar
06Gcoupin
I Guarantee you, that was the problem.
Old Jan 14, 2008 | 10:23 PM
EnduroMTS's Avatar
EnduroMTS
Sorry for the late response guys! We've been busting to get this car back on the ground. 06Gcoupin It's was the flywheel. Good call
All we have to do now is put everything back on, Cats and exhaust and this bad boy will be back on the ground! I'll be sure to take some pictures soon its down.
Still a few things we want to add to this ie; gauges! then it can get its massive widebody put on!
I'd like to thank everyone for helping me out with this, great community! thanks everyone! :biggthumpup:
I'll keep everyone posted!:thewave:
Old Jan 15, 2008 | 06:18 AM
mark5's Avatar
mark5
are you on g35driver.com?
Old Jan 15, 2008 | 08:44 AM
EnduroMTS's Avatar
EnduroMTS
Yup!
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Dymsi
Sep 29, 2015 11:32 AM
