Help!
Old Mar 12, 2008 | 06:33 AM
Mixturepinoy's Avatar
Mixturepinoy
Question Help!
This morning I went to warm up the car. Upon start up all lights on the dash seemed fine. Then when I began to drive it a few lights went on, brake, slip, vdc off, and [!]tps. I ran it for about half a mile until i pulled over and turned the car off for a minute. I turned the car back on and the lights were still there. I drove the car for a good 2 miles or so with those lights still lit up. There's no CEL light lit up, just those 4 lights. I have an 04 5AT coupe w/ almost 82k. Anyone have an idea why this happend? Thanks
Old Mar 12, 2008 | 06:53 AM
superchargedg's Avatar
superchargedg
Damn Noobs
For the tps check your air pressure for the other lights check and make sure you have enough brake fluid.
Old Mar 12, 2008 | 07:14 AM
meyerman's Avatar
meyerman
I have been told by a dealer, that your dash lights , light up like that when your brake fluid is low. If yout brake fluid is low, your vdc, slip system will not work. They also mention that your brake pad might by low.
Old Mar 12, 2008 | 07:50 AM
Mixturepinoy
hmmm.. i'll check on that..
Old Mar 13, 2008 | 02:36 AM
jedmo123's Avatar
jedmo123
What's up Mix? Did you get this one figured out?
Old Mar 13, 2008 | 06:48 AM
Mixturepinoy
Okay. so another forum member on g35driver had the same problem and he had it checked out at the dealer. He said it was his speed sensor that was out of place that caused it. I figured it was the same for me since i did have to temporarily move it upon installation of my springs. I checked and it was fine. Then i checked my brake fluid level which was mid level between MAX and MIN, so i added a little bit to fill it to MAX. I drove it a couple miles and the VDC and SLIP light turned off. BRAKE is still on.. I'm thinking it may be my rear pads.. i'll check them out tonight.
Old Mar 13, 2008 | 06:52 AM
ChristianN's Avatar
ChristianN
Are you still driving around with your e-brake on, Tito?
Old Mar 13, 2008 | 06:53 AM
Mixturepinoy
Nope' i took off the pedal long time ago
