Dropping weight on the g35...
Originally posted by racingdynamcs
how much weight can be dropped from the g35 coupe ....
Easy way - reduce 'unsprung weight' by using Real Racing Wheels or Diamond Racing Wheels instead of stock or most aftermarket rims. Downside is sizing issues (it's not easy to find 17-inch and larger racing wheels) and styling plus legal issues (I believe that most racing rims are not street-legal.) While you won't lose a lot of weight it will be in the crucial area of unsprung weight.
Easy way #2 - lose your spare tire. That's what Infiniti Roadside Assistance is for (or Triple A!) This is not unsprung weight unfortunately, but it is very easy to do. I do it every time I AutoX my coupe.
Hard way - my first impression is that to avoid big money costs of using alloy replacements for engine parts or fabricating plastic body panels to replace sheet metal is to yank the back seat. That might lose you up to a couple hundred pounds depending on how aggressive you are with the removal and how concerned you are with the appearance.
If you are losing weight to race the coupe - AutoX or track - you might not care about appearances, but if you are just doing it for general handling on the street you will probably want to be a bit conservative on how much you gut the interior.
Hard way 2-? - replacing front seats with racing seats, stripping interior down to metal, removing a/c, stereo, speakers, amps, NAV and SAT, basically making your car into a racing machine.
Good luck - the coupe (and the Z too) are kinda porky - but boy, are they sweet chubbettes!
- Riff
exhaust / headers are really heavy on the stock G ... ill be replacing most of the exhaust with staight pipes in the next 2days...and...that should ive way to 15rwhp and free up weight...
