Coupes using 245/40ZR18 front and 275/40ZR18 rear
Old Jan 2, 2004 | 05:44 AM
blug35c's Avatar
blug35c
Default Coupes using 245/40ZR18 front and 275/40ZR18 rear
It is time to replace the tires on my 6 M/T coupe. For those who have switched to 245/40ZR18 front and 275/40ZR18 rear how are they doing? I am curious how the rears are on the 8" wide rim.
Old Jan 2, 2004 | 04:06 PM
lowrider's Avatar
lowrider
Three forums now, huh? The answer is still DON'T DO IT?
Lou
Old Jan 2, 2004 | 06:36 PM
blug35c's Avatar
blug35c
Lou
Yep and read all three of your answers. Problem is the question is posed to those using the setup, as opposed to those who just want to say no!
Old Jan 2, 2004 | 07:28 PM
themyst's Avatar
themyst
The problem is not many will be running 275 rears on 8" wide rims. Thats just asking for trouble. I ran 275 rears on my TE37's (when I had my 350Z) on a 18x9.5 rim. What you're looking to do is not feasible. If you want to run 275 in the rear, get new wheels.
Old Jan 3, 2004 | 05:39 AM
lowrider's Avatar
lowrider
themyst
This guy's not worth our time.
Lou
Old Jan 3, 2004 | 07:29 AM
2003z's Avatar
2003z
fwiw, One of the top autocross guys runs 275s on his stock 7.5/8" wide 17s, and puts the sidewalls through a lot of stress without popping the tire off the rim, so it can be done safely, you will just have a lot of bulge.
Old Jan 3, 2004 | 08:15 AM
blug35c's Avatar
blug35c
themyst
Lou
Lou,
Just because people disagree with you is no reason to bad mouth them. Rather then blasting people why don't you try to be positive and rather than saying don't do it or it is a liability why not share with the readers exactly what the issue is. If you check the 3 forums several are running the size I mentioned with no problem. If you could tell me and the others what the tire will do that is so dangerous that would be a big help.
Kirk
SAE Engineer
Old Jan 4, 2004 | 11:12 PM
articfury's Avatar
articfury
Charter Member #55
Kirk,
Check the tire manufacturer specs for a 275.
What is the MIN wheel size they specify for a 275 tire?
All are 275/40 18, except where noted:
Bridgestone S-02: min wheel size 9” - recommended 9.5”
Yokohama AVS Sport : min wheel size 9” – recommended 9.5”
Toyo Proxes T1-S Ultra: min wheel size 9” – recommended 9.5”
Pirelli PZero Asimmetrico: min wheel size 9” – recommended 9.5”
Continental ContiSportContact2 (275/35ZR18): min wheel size 9” – recommended 9.5”
Noticing a pattern yet?
It may be POSSIBLE to put a 275 on an 8” wheel. It is just not a good idea.
It sounds like you are just looking for someone to tell you to go ahead and do it, since you don't want any input from people that aren't running the setup. If you have been to 3 forums and asked the same question, but haven't gottent he answer you are looking for, maybe you are looking for the wrong answer.
In the end, it’s your choice, Kirk, but why would you want to run something that is SOOO far out of spec. As an SAE Engineer, you should know that running things far out of spec is not a good idea, nor the optimum solution.
Like themyst, and others I'm sure, said, if you want 275's in the rear, buy new wheels, or find someone to widen your stock wheels.
As for the autocrosser, what tire is he running? Hoosier recommends a 10” wheel for their 275/35 18 and a 9.5” wheel for their 275/40 17 DOT tires.
I find it hard to believe that a 275 tire on an 8” wheel is anywhere near a optimum setup. If he does wheel with that setup, I can't imagine what he would do with a properly sized setup.
D
Old Jan 5, 2004 | 04:27 AM
blug35c's Avatar
blug35c
Originally posted by articfury
Kirk,
D
Thanks for the info. I have rec'd several PM's from folks running the setup I mentioned. All of the info has been helpful thanks.
Old Jan 5, 2004 | 08:00 AM
2003z's Avatar
2003z
D
He's a national champion autocrosser and he runs hoosier 275/(40, i think) on stock front 7.5" rims and rear 8" rims. Can't go to a wider rim and stay in stock class.
Old Jan 5, 2004 | 06:30 PM
blug35c's Avatar
blug35c
"It sounds like you are just looking for someone to tell you to go ahead and do it, since you don't want any input from people that aren't running the setup. If you have been to 3 forums and asked the same question, but haven't gottent he answer you are looking for, maybe you are looking for the wrong answer"
Not at all my friend. Check the posts. Several running the setup I am looking at with no problems. I am not looking for any one's approval. Just interested in actual user feedback. Is that so unusual? Thanks anyway!
Old Jan 5, 2004 | 08:20 PM
g35bh4ve's Avatar
g35bh4ve
I use SSR GT-3 Front: 19" X 8.5" with 245/35/19 and Rear: 19" X 10" with 285/35/19, and I like it. They give me much better handling and heavier steering feel.
Attached Thumbnails Coupes using 245/40ZR18 front and 275/40ZR18 rear-dsc02716.jpg
Old Jan 5, 2004 | 08:21 PM
g35bh4ve's Avatar
g35bh4ve
Default Clifford Matrix RS3.5 and Clifford GPS Tracking System
You guys might consider to install the Clifford Matrix RS3.5 Alarm system with 1/4 mile 2-way communication remote. This system can be installed with or without auto start. The secutiry part includes dual stage shock sensors, electronic starter kill, and door protection. You can also add perimeter sensor for the convertible owners. You will be notified from your remote control (with LCD screen) once the alarm has been triggered. It can also be connected to Clifford GPS Tracking system that allows you to track/locate the vehicle, arm/lock, disarm/unlock, and remote start via cell phone or online anywhere nationwide. Example: You can be in New York and you can warm up the car in Houston if you want to, and you will be called/e-mailed in New York if somebody tamper with your car in Houston. You can also activate the Speed Limit Notification which you will be notified if someone is driving the car over 75 mph. You will also have 60 days vehicle log when you login to your account. The log will display all activities including the alarm activation and overspeed at certain mph at certain date and time. You can contact Andy from Executive Motoring at 713-467-7000 if you are interested. They also do high end windows tinting, clear bra (Laser pre-cut/pre-molded, non fading/non scratch material), factory module XM/Sirius radio, custom audio, navigation, and multimedia systems.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
